6 minutes ago, drifter17a said:
Mine is gtt r34 with 500 bhp looking to boost up to 650 as it is forge so think having heavy might not be that bad at the end due to power.
just worried it won’t shift in cold morning
It's not just the horsepower figure, it's the torque and drivetrain. You may be able to get away with lightweight, try it first and see if it grinds at all.
47 minutes ago, joshuaho96 said:
If the synchros are on the way out some lightweight shockproof will help but only delay the inevitable. Don't shift quickly, double-clutch your downshifts. You will be able to get a bit more out of the transmission before rebuild. Don't try to DIY a transmission rebuild unless you feel like taking the transmission out multiple times. You will save a lot of money if you're willing and able to drop the transmission yourself, that's a good chunk of change right there.
It's been 8 years now, ~80000km, and no change in shift quality on my box from the first time it managed to change gears with smurf's blood in it.
26 minutes ago, drifter17a said:
i take it your box was worn so it won't shift and redline brought it back ?
Yes. I bought it for Neo my engine conversion and it changed gears nicely when not spinning, but would not while the engine ran. Changed to lightweight and it would change gears straight away.
new refurb one is around £1300 and want to kill this, buy one next year and then swap.
I can never understand the "kill this" mentality. I bet you I could happily drive your gearbox for the next 10 years.
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
