All,
engine forge rebuild with full balancing however it smokes which is minimal and i think it is due to rich mixture as can smell fuel
pcv is to air so manifold return is blocked off.
 When on i can see mist of smoke on idle from catch can which is strange and wanted to seek opinion here before going back to tuner
Has anyone here followed the hpacademy as looking to learn and tune the ecu myself . I have purchased their engine rebuild course and it is quite good
https://www.sau.com.au/forums/topic/480293-rb25-forge-rebuild-smoke/
Did you run it in hard with mineral oil or baby it with synthetic oil? If you don't run it in properly you will end up with glazed bores and rings that don't bed in. Have you measured your oil consumption?
Re the tuning do you have a wide band sensor installed?
By run in do you mean inserting piston or bed in?
i didn’t do it as tuner did and remember on one of the pics there was fair bit of oil in bore and he said it was the bore oil
it has done 300 miles since and expect to return and change oil at 1k ( bed in period)
I did ‘t rebuild but with a tuner having 10 years of experience and many skyline seen there then I would have though all rings are clocked( not aligned) unless he has given it to one of his workers and they have f**ked up
re run in, he did and I wasn’t there . I got it back after car had run in excess of 5 hours and currently on 300 miles of the bed in oil
would you use baby oil for first start up?
hmmmmmmm..
Need more info man. there are many reasons an engine can smoke, with different causes. But realistically you should be directing your questions and concerns should be directed to the builder.
You need to read more carefully. There is no mention of baby oil anywhere.
The run in procedure is important. I would want to be there.
To repeat a relevant question have you measured any oil consumption?
oh was going to bed and red it as baby oil :)
nope but will check it today. It has an extended sump with 7 liter oil capacity buffled  custom made
  • 1 month later...
26 minutes ago, John iatrides said:
Yes, it will cause smoke if one got damaged or wasn't fitted properly.
A valve without a stem isn't a valve, you are refering to valve stem seals, big difference!
Run a compression test to see what all your cylinder pressures are that will show if the rings seated. I'd call your tuner up and ask him who built your engine to c if they reused valve stems or maybe didn't install one correctly or tell your tuner what's going on he should have the best insight on the topic.
    • The steering wheel on my 97 s3 gtr is a little bit worn out, so im on the hunt for something mint. I notice that this type of steering wheel is on several other nissan's of the era.  Does anyone know if their all identical, or are there slight differences? I feel like gtr tax applies to anyone selling one, but if it comes from any other car the price is much less, even though its the same design.  Chat gpt says the material for the gtr is slightly different and it says gtr on the wheel, but every pic ive seen it just says nissan.
    • I might have to say it.
    • Ahh... it's an early RE5R01A box, that means the pinouts I gave are wrong (they were for the RE4R01A 4-speed box)... I'll have to dig around in my docs to see if I've got that schematic (they used the same gearbox plug, with the vacant pin wired to the direct drive clutch solenoid)...prolly hidden away in a supplement somewhere... ...there were 3 variants of the RE5R01A ~ this early schema was what we called the 'dumb' 5 speed ; it's what jatco called a 'medium duty' box, with torque holding up roughly ~200ft/lbs or so, which was good for NA from RB20/25DE and up to around VG30 output spec. With the RB25DET (and VG33/35 mills), the only options they had was the 4-speed 4AX00 box, which had been beefed up to handle the extra torque (primarily for the VG35, but it also suited the RB25DET mill and others)...and the RE4R03 box in large 4WDs a lot of the time... ...the next variant of 5-speed was redesigned, stronger, and 'smart'...first ones had external TCU with internal (on valvebody) Shift Control Unit, pressure switches, and 2 x TSS...and the last ones had internal TCU+SCU setup, with CANbus control etc etc. @DRoc81 On the RHS of the box towards the rear, there should be a stamped silver ID tag -- what's the model number? Oh...and with the early 5-speeds, the torque converter control solenoid assembly should be replaced as well (31940-60X00)...it's a bit Murphy's Law ....if one has failed, bet on the rest not being far behind ...
    • I remembered wrong, but was close though 1Kz setting because those Jaycar SSRs don't go any faster, 1x pump per SSR with flyback diodes & heatsinks. In saying that, the heatsinks are overkill. Just on an alloy plate is more than sufficient. You'll find without a flyback diode, your SSRs will heat up big time and also die prematurely.  I've been running the two same SSRs since the last motor, no issues, car does 2 hour straight drives in summer once in a while and gets punished on the track. Nothing melts, no hot messes, etc.
    • Hmm. You're probably best off working out what the lobe centreline or even the LSA is for the stock cams, with VCT OFF. That's bound to be out there somewhere. Then, work on the assumption that the Kelford centreline is probably the same, and wouldn't be more than a couple of degrees away, if it is different at all. I'm very surprised that you needed to adjust the exhaust cam by 5° to get it on spec. That screams there's another problem somewhere. Anything from the belt being 1 tooth off (how many degrees is one tooth worth?) to simple user/measurement error on the degree wheel. I say this because Kelford, like most quality cam manufacturers these days, does a pretty good job of actually making the cams to spec, not relying on patching it up afterwards like we had to do back in the 80s.
