I shouldn't think so. So long as what the Regency boys would consider the "emissions controls" are all in place then an FFP is not really changing anything that they would be upset about. Of course, that then opens up a whole can of works, because there would be little point in putting an FFP on a car that still had all it's original emissions controls, which includes the unmodified ECU.
Once you have a bigger turbo, to justify the FFP, and possibly a different throttle body, and at minimum have Nistuned the ECU to handle these changes, you are no longer "legal" and would need full engineering of the mods to not be defectable. And of course, engineering for ECU changes invites the emissions testing saga, which is $$, etc etc, blah blah.
The other aspect of an FFP on a Skyline is the problem of cutting a hole anywhere to pass the intercooler pipe through on the driver's side. Most such holes are defectable. It doesn't matter how "non-structural" you think any particular piece of steel is in the front end, they say that it is part of the original crash structure and cutting a hole in it will change the crash performance.
  • Like 1
My curren engine bay, wanting a clean look.
After some ideas how to clean up a 32 gtst engine bay.
So far I'm welding all the holes up, re routing the brake lines, shifting the battery and windscreen bottle to the boot and shifting the fuse box to under the dash.
aren't the rules here 2 intake mods allowed fmic and pod filter would take it up
but yeah safe to say it'll be a defect anyway seeing as they can get you on suspicion anyway.
Good to see you're still kicking around in 32 land
No, that's Victoria. SA has always been far more reasonable. Not necessarily easier, once you actually do change stuff, but definitely more reasonable. Hence my authoritative statements in my first reply.
good to know. i was just speaking from past experience where if it looks modified they are well within their rights to send it for inspection.
though i did find this on the SA.Gov.au site. https://www.sa.gov.au/topics/driving-and-transport/vehicles/vehicle-standards-and-modifications/engine-and-exhaust-modifications
No alterations to the engine's camshaft, inlet manifold, carburettor/fuel injectors, engine control unit or the catalytic converter are permitted.
Modified or aftermarket plenum chambers or throttle bodies are not permitted.
2 minutes ago, GTSBoy said:
Ooh. I would not have expected that. I wonder when they started saying that? It's been a few years since I last spoke to anyone at Vehicle Standards.
yeah its odd that it specifically mentions plenum chamber modifications. someone must have done something to get them to specifically rule it out.
maybe it was those hidden NOS ones haha
    • One other question, is there a chance that changing the idle speed can lead you down a rabbit hole and is the reason the tuner didn't touch it? Reason I ask is because if that's the reason the tuner avoided it then I probably shouldn't be touching it lol.
    • Pfft. As if I'd ever point a high pressure washer at my car.
    • The nature of my commute has changed. Way back then it was traffic lights all the way, for ~28km. It sucked. When they finally stitched the expressway together I could do a good 15+km of it at a steady 80-100 with no stopping. That alone has gotten me down to flat 10s. Prior to that it was mid-high 10s. I can't remember the delta that I saw when I got the idle down. It was only ~150 rpm, because the idle speed was never terrible, but for the delta in consumption to be noticeable it would have had to have been at least 0.2-0.3 L/100km - which is not to be sneezed at when it comes for absolute free. It's only about 50L per year, but that's ~$100. A few extra pizzas is always welcome. Note that I have a record of every tank of fuel that has ever gone through my car except for a handful put in by someone else, like my mechanic. I can show you the difference between stock RB20 and tuned RB20, stock RB5Neo and tuned, winter and summer fuel blends, winter and summer fuel blends when the ambient temperature is not appropriate for the blend, working O2 sensor, blown O2 sensor, boosting f**k out of it and frightened to boost it because it is pinging, and so on. OK, I probably can't do all that now with 100% clarity - but at the time when any of those things were in event, you could see it in the records. There's 25+ years of simple tank after tank records, so you have to look for landmarks to work out approximately how old any single record is. What's really important is the meta data and that lives in my head.
    • If you're claiming the issues are not skyline specific, then either the USA is living in the 90s / early 2000s, OR you have the issue of "survivor bias". Which is you're mainly hearing and listening to those with terrible experiences, and haven't found the guys who have cars with good decent builds and no problems. It happens in AU too, that plenty of people keep having issues, and they keep going to the workshops that are known to be shit "because I read on the internet". Even worse, are those who keep posting on the internet as though they know for a fact what something is, when they've never touched/looked at said item in their life, and again are making assumptions, based on something they read, or because it's a certain way in other cars. It's even funnier when those same people debate the facts with the people who've lived and breathed this stuff for over 15 years. Example, I've had someone tell me you can't do something with a Skyline, because they read it on the internet, except I can tell they're wrong, as I did that exact thing back in 2008 with my Skyline.
    • The funniest part I saw, was someone would bitch and moan on FB about something, Andy would be the one to respond, asking for more info, if he could contact them, what the engine setup is, what their config file was, and 95% of the responses were people just going "der! It doesn't work" and Andy going "What doesn't work?" And then going "The firmware!" And they'd go around in circles as no one could ever give information, and Haltech couldn't fault things on the bench, (especially when people wouldn't give any specifics).   Many moons ago, when Andy was back at e420c stage, he reached out to me, and asked me to test different plug and play looms for him (already had an e420c in the car on his V1 PNP loom). And he kept asking me, as I was competent enough to be able to give him some specific feedback on what was/wasn't working, how to replicate the faults etc, and work through things with him. Most people are terrible at answering the questions they're asked, or being able to provide quality feedback other than "it doesn't work".
