i have a noisy bearing ( i think ). well in netural with the clutch out you can hear it, also in all the gears when driving except 4th gear.
which bearing would it be and why is making a ratchet? it hasn't changed in about 6 months and doesn't seem to be getting worse.
i'm looking at getting a gtr gearbox later on but will nulon G70 help the noise at all?
or do you know anyone that has a GTS4 gearbox in good condition. :rofl:
Thanks guys
https://www.sau.com.au/forums/topic/48031-gearbox-bearing/
Sounds like ur thrust bearing. i have a similar issue with my car but aint bothering me. I was told by a mechanic that i should be good for another 10000kms. I will wait til the clutch goes as well and do it all together.
All depends on how bad it sounds. If its not too loud, just wait til you put the new gearbox in. Or put in thicker oil but you might put more pressure on the gearbox.
good luck
https://www.sau.com.au/forums/topic/48031-gearbox-bearing/#findComment-973581
well i had the thrust bearing and the throw-out bearing replaced with the HD GTR clutch i got put in. but i got a price of $300 for labour to re-bearing the box so i might got that way and then i will know what condition it in.
https://www.sau.com.au/forums/topic/48031-gearbox-bearing/#findComment-974351
got the exact problem, wasnt clutch or bearing coz got them fixed and still there, mechanic told me its the bearing on the driveshaft or something, he said it wont do major damage on mine atm but mine only sounds grindy in 1st or 2nd and its not too loud...
reason for that happening to mine, when i 1st got the car i took it to the dealer where i bought it for a clutch change (under warrenty) when he drained the gearbox oil he forgot to replace it so i drove from sydney to wollonong without it not knowing...consumer affairs got involved the dealer doesnt do imports no more and the mechanic dissapeared b4 we could go for compensation...
in the end i got a bad gearbox and the work was not under warrenty...
cheers...ben.
https://www.sau.com.au/forums/topic/48031-gearbox-bearing/#findComment-977527
I have an input shaft bearing problem. Basically got a nice whine to the box when the foot is off the clutch and in neutral. Added Nulon G70 and it did stuff all for the noise... Its been like this for 2 years, and I havent had any hiccups yet...
https://www.sau.com.au/forums/topic/48031-gearbox-bearing/#findComment-978321
ok... well i'm going to install a GTR box so i don't think i'll have any problems with it breaking on the RB20DET.. hehehe..
just have to find someone that will install it for a good price in brisbane. anyone?
https://www.sau.com.au/forums/topic/48031-gearbox-bearing/#findComment-978790
    • Standard GTRs are boring and there plenty of them, do what ever you want to it and just remember nothing about them is cheap anymore and if you’re picky about how you want things done it gets even worse.    if it’s an n1 or something very limited then maybe care more about it’s heritage
    • Alright guys, I've got good odds the motor survives due to a majority of spare parts. Who's taking bets on clutch, who's on transmission, and who's go diff? Happy to also take bets on if it still overheats in traffic or not 😛     Car looks amazing by the way. I've never been a fan of R34 rears, so really, I don't think any body kit etc solves that for myself, but the front end looks amazing!
    • As an ex-skyline owner Going off how these things are now "modern classics", I would keep the twins and just "refresh" bits that are required for reliable power and have a car you can take out for a cruise whenever you get the itch As a idiot who cannot leave things alone Going deep into the "rabbit hole" is a easy thing to do, as previously mentioned, once you start it becomes a slippery slope, wirh lots of supporting mods, and possibly rebuilds, and unless you have a bottomless pit of funds, the car can spend most of its life sitting in the garage,  broken, waiting for parts, or building more funds For a classic like a R32 GTR Basically, a reliable OEM+ refresh, that isn't a broken garage queen, is alot better than a car that you build, then break, then fix, then break again And it isn't just the engine you need to worry about, these beasties are getting on in age, and all parts are getting, and have got, expensive, the days of picking up cheap replacement engines and other driveline parts are well and truly over The funds not spent on going a single with quality parts, and with all the other other bits required to make it happen, could be spent on refreshing alot of other parts A wise man once said "If you cannot afford 2 GTR's, you cannot afford 1", I also believe he said this about 20 years ago when you could pick up a clean R32 GTR up for around $20k My advice for a R32 GTR (the one and only true Godzilla in my mind) is to think holistically about the whole car, the body, the power train, the suspension, the brakes, and the driveline SAU is a wealth of knowledge with decades of Skyline experience,  from stock, to OEM+, to modified to varying degrees, to full on or weekend or dedicated racecars, as well as full on money pits that rarely leave their garage Treat the old girl nice and give her what she deserves, you are a lucky man to own such a classic car
    • For that price you could buy the hypergear turbo (big fan as I run one) and the Haltech ECU..
    • +1 for the Elite 2500. Get some new knock sensors while you are at it (pretty cheap), look up the TAARKS Nissan knock sensor kit. You may also want to get new coils (R35gtr) while your at it (assuming your on stock ones), as they are a liability. Mine started right up and idled fine on the base map. Also go MAP over MAF, as said above, Haltech make this super simple right out the box. Another fanboy of DBW here, Outsider Garage from your neck of the woods make some nice conversion gear for the R33 (that’s where I got some of my gear from).
