DIY:
Hicas ball joint removal & replacement / Gktech lock bar install.
Job:
Replace worn out hicas ball joints, without removing hubs.
Fit hicas lock bar.
Parts needed:
Gktech lock bar
2x Hicas ball joints
Tools needed:
Jack, Jack stands, WD40, Grease, Impact wrench, Adjustable wrench, Socket set 10-30mm, Circlip pliers, Pliers, Ball joint press kit, 42mm O.D. x 37mm I.D. x 60mm Steel pipe, Pitman arm tool, Angle grinder, Breaker bar, Safety glasses, Hearing protection, Mask.
Duration:
3-6hrs.
Difficulty:
Medium - Easy with the right tools.
Step 1:
Remove rear seat, remove battery earth and remove suspension.
Then carefully jack up the car and use jack stands.
Step 2.
Spray wd-40 on the bolts, remove split pin and 17mm nut from ball joint/tie rod end.
Step 3.
Use pitman arm tool or suitable tool to remove tie rod end.
Step 4.
Crack the tie rods from the hicas unit under the rubber boot, unplug the hicas wiring.
Step 5.
Remove the 19mm bolts holding the hicas unit to the car and then remove the tie rods.
Step 6.
Install the tie rods into the gktech lock bar leaving the rubber boots loose.
Set that aside for now.
BALL JOINT REMOVAL.
Step 7.
Remove circlip from back of ball joint.
Step 8.
Cut the ball joint stud to allow more space to remove.
Step 9.
If you haven't removed suspension do it now.
Use the ball joint press tool to press the joint out.
Most kits don't come with a small enough size pipe to allow for extraction of the joint, so you will have to find a steel pipe of 42mm O.D. x 37mm I.D. x 60mm. Very common pipe size fits perfectly.
Carefully align your press tool with the pipe on the hub. I used 5mm steel plate as a backing plate and then used the correct size socket to sit flush on the back of the ball joint. This will allow you to push the ball joint through the hub towards the rear.
Step 10.
With the ball joint removed, clean the ball joint housing with wd40 and a rag.
Step 11.
Apply grease to the joint and housing.
Step 12.
Use a 30mm socket or similar sized pipe that fits over the rubber boot and sits on the metal rim of the joint to press the new joint in.
Align the press tool with the socket and ball joints rim and start to turn the press tool to insert the joint into the hub.
Joint installed.
Step 13.
Reinstall the circlip to the back of the ball joint.
Step 14.
Cable tie the hicas wiring out of the way.
Install the gktech lock bar.
Tighten the 19mm bolts. Check the tie rods are tight, then secure the rubber boots.
Step 15.
Install the tie rod ends and replace the 17mm nut and split pin.
Step 16.
Reinstall suspension, rear seat and wheels.
Remove hicas bulb on the cluster, or cut hicas warning light wire on hicas cu in boot.
Get wheel alignment.
All Done.
Edited by dyl33
Mental notes;
  1. The above is valid for electric HICAS, like 33 & 34. Not same same for hydraulic 32 HICAS.
  2. I shudder when I see chassis stands under the rear end of the chassis rails. It's too far forward for a stable support and it puts a lot of leverage from the mass of the rear of the car on the contact points and drives dents into the chassis rails. I prefer to locate them carefully under the subframe.
  3. ...
  4. Otherwise. Good.
  • Like 2
6 minutes ago, GTSBoy said:
Mental notes;
  3. ...
  4. Otherwise. Good.
1. Correct.
2. I'll take note. There is 4 stands under it, the blue 2 are on the subframe.
3. ...
4 .?
I wasted so much money on the Frenchy's Performance Garage tool. I'm sure it's great if your balljoints are in good condition, but I ended up stripping the coupler nut, and bending the threads on the balljoint trying to use their removal tool.
I basically ended up doing the exact same thing as this guide to remove mine, and they came out like butter.
I used a torch to heat the knuckle up for around 60 seconds, and I used my 36mm axle nut socket as the retainer. I then used a thick washer on the back first, before putting a 14mm socket on the back to push it the rest of the way. This process took about 15-20 minutes per side, compared to the hours I spent trying different methods. Using the 36mm socket it has the dpeth that you don't need to grind the end of the balljoint off either.
Edited by Jarsky
  • Like 1
  • 7 months later...
1 hour ago, Bart Japan said:
Does anyone know how to do a 32? Do you get a fitting that recirculates the HICAS?
If you don't want to remove the lines, I'm selling this spare kit.
134044532_10159572282190400_5239933425189596540_n.jpg.a37065c2d7f4799d69fc20317d281bf5.jpg
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
    • Slight segway but the most expensive part of the whole thing which I would have thought would only be required for an engine size/type swap, not a VIV test, is emissions testing.  That's when you get into the big bucks.  I can't remember the exact price now but I got quotes for the GT-R based on swapping to RB30 (not that anyone bothers doing it legally anymore...) and it was around $4500 just for that alone.  The guy that does them manipulates the tune on the vehicle to make sure it passes.  The cheaper option is to book into Kangan Batman Tafe (I think that's where it was) and hire their tester.  Allegedly you're not allowed in there with the car though so not in a position to tweak anything to make sure the vehicle passes.  I'm sure in this day and age of ultra tuneable ECU's you could get the tuner to program a special efficiency (clean) tune that emits the lowest amount of particulates possible that would pass the test.  It might only make 50kW's but as long as it passed who cares!
    • I'm sure he has left signs, or, he is looking down, laughing That's my cunning plan for when I leave, lots of half finished projects, with no rhyme or reason of where I was actually up to, just to keep everyone on their toes
