So I was doing research on oil rings going bad they can either seize up or break. If they are seized do you think it's a terrible idea to fill every piston all the way to the top with seafoam and let it sit for a few days ( I will of course not start the car until on the cleaner is gone, and will change the oil before i start the car). Hydrolocking is the main concern of course, but should the seafoam completely dissolve after a few days of sitting?
https://www.sau.com.au/forums/topic/480338-how-to-clean-oil-rings/
Having a similar problem with a 370Z I just acquired rather cheaply that was using a bit of oil on no1 and blowing smoke on start up and had high misfire count  on no1 as well as a result.  I had hoped that it was a valve stem seal and might be easy to fix but now don't think it is.  Compression is still pretty good so think that it is a gummed up oil ring ; as in my experience it is rare to break rings now days and the car had a very poor service history.  I soaked overnight in lucas oil additive and it did not do much and then tried overnight with Marvel Mystery oil and improved a bit and then tried a concoction of wynns, nulon and no name brand cleaners.  I could not find Seafoam here in Australia but the Nulon hinted at being similar. The top of piston and inside seems pretty clean now when I put a bore scope down the plug hole but sadly problem has not disappeared but has improved somewhat.  I was doing an oil and filter change after each of these treatments along with an engine flush.  Am just going to drive a bit for now with no more engine flushes and try some valve/ engine stop leak /additives and drive it for a bit and see what happens.
did u have a rough warm idle?
    • Hi...a little refresh. Is Nistune gonna be enough to run BoV? Or do i need some proper ECU?
    • Yep that's pretty much what I want to see. Racecars that look and sound like the Group A but with newer tech underneath to make them faster and safer. I'm sure there's enough VK-to-VN commodore, E30 BMWs and Foxbody mustangs shells around to make up a decent number of cars with hopefully a couple of sierras, rx7 and R31s in there too.
    • Contact Jessestreeter.com/Skevas Racing/JustJap for a new r34 rb gearbox or go a cd00# conversion. No point playing with unknown condition gearboxes.
    • Such a shame places like Amaroo Park have been redeveloped, smaller tracks always make for good racing. Cheers for sharing @PranK there's some good Lakeside video's too. Its so hard with older the cars as parts are so rare and everything was made for a particular chassis at that point in time. Even the V8 Supercar Blueprint era cars are all different between each chassis within a team as they learnt things and made improvements. The COTF cars between each Chassis builder is different too especially motor/oil systems/intakes. The Group A stuff is worth so much too especially chassis with good history. The only way to do it would be composite panels and similar engine drivelines to the original cars. Ford sierra running Focus RS driveline, Commodore running a short stroke LS/LT or a Falcon with coyote and a H Pattern dog box. Could use a standard ecu across all models with a Torque Map and DBW for parity which is not even used in Supercars currently. Hell a TCM is almost a full chassis car these days and the suspension is not even close to standard style in the front running cars.
    • Dashcams Australia (13/05/25) captured JDMHSE (Vic plate) being a right tosser.
