So I was doing research on oil rings going bad they can either seize up or break. If they are seized do you think it's a terrible idea to fill every piston all the way to the top with seafoam and let it sit for a few days ( I will of course not start the car until on the cleaner is gone, and will change the oil before i start the car). Hydrolocking is the main concern of course, but should the seafoam completely dissolve after a few days of sitting?
https://www.sau.com.au/forums/topic/480338-how-to-clean-oil-rings/
Having a similar problem with a 370Z I just acquired rather cheaply that was using a bit of oil on no1 and blowing smoke on start up and had high misfire count  on no1 as well as a result.  I had hoped that it was a valve stem seal and might be easy to fix but now don't think it is.  Compression is still pretty good so think that it is a gummed up oil ring ; as in my experience it is rare to break rings now days and the car had a very poor service history.  I soaked overnight in lucas oil additive and it did not do much and then tried overnight with Marvel Mystery oil and improved a bit and then tried a concoction of wynns, nulon and no name brand cleaners.  I could not find Seafoam here in Australia but the Nulon hinted at being similar. The top of piston and inside seems pretty clean now when I put a bore scope down the plug hole but sadly problem has not disappeared but has improved somewhat.  I was doing an oil and filter change after each of these treatments along with an engine flush.  Am just going to drive a bit for now with no more engine flushes and try some valve/ engine stop leak /additives and drive it for a bit and see what happens.
did u have a rough warm idle?
    • Change the transmission fluid. I would try Motorcraft XT-M5-QS if you have it in your area for a reasonable price. Also, double check your clutch is fully disengaging. If you are not pushing the clutch pedal to the floor fully for every shift now is the time to start. Make sure the clutch is fully bled. The damper line requires two distinct bleed points to be purged of air or it will not disengage the clutch properly. If either hydraulic cylinders input or output are losing hydraulic pressure in their seals/leaking you can have problems like this. If you've ruled out everything else then the most likely explanation is the synchros are worn and you need to double clutch the shift or rebuild/replace the transmission. The transfer case is discontinued FYI so you may want to rebuild it while you're in there too. If the chain stretches past spec it can do a ton of damage.
    • You're selling the SS?! How much are you asking on it?
    • My answer would be, that depends. If it's something that can be grumpy to start, runs a bit rich, and is likely an expensive engine, then yes, I would. But there's a few reasons why. Sumps aren't really sealed, there is airways to them, so it is technically open to moisture. Secondly, if as mentioned it has been started, and it's a fuelled up, I'd dump it, as chances are, fuel is in the oil. Next to that comes, how much use had said oil seen before it was parked up. IE, how much carbon, and potentially fuel/water did get in there while it was being used, and has now been allowed to sit, and slowly come together? For the most part, if it's just been something like a road car, stock engine, nothing wild, f**king send it if it's not near oil change spec.
    • I forgot to say Mark, you know how if you lack sleep, we get Grumpy Mark? When I lack sleep I'm Grumpy Matt. We must be the GrumpMa's!
