Hey guys, I’m looking into buying a r33 gtst series 1 and want to know if anyone knows what is required to get and install a full 400R style body kit, or atleast front bumper, side skirts and wing. Are there any major medications that have to be done to the car?, and for those who ask I want to get a series 1 as I don’t want to have to hassle with nsw steering wheel airbag laws.
https://www.sau.com.au/forums/topic/480348-r33-gtst-400r-style-body-kit/
You'll need 400R style reps of the rear bumper, skirts and arches which are easily available for GTSTs but the front bumper will be the tricky bit. You'll also need a GTR spoiler which is not exactly the same but close enough.
The replica front bumpers that most people get have a different bottom lip and look kinda ugly if you ask me. The center section is raised up and is missing the center vents.
There are reps that look like the real thing but very rare to come by, expensive and usually for a GTR. To fit one of them, you'll need GTR front wings and headlight spacers. Aftermarket wider wings will work but you'll lose some of the 400R look obviously. Other option I can think of is you buy a 400R lip, and mould it on the GTST rep, which may need cutting and shortening slightly.
I’m looking at getting these as they are made specifically for the series 1 gtst and should fit without too much hassle
frontbar http://www.uniqueautosports.com.au/Parts-Shop/400r-style-front-bar-with-grill-r33-gts-t-series-1-862.aspx
rear bar
http://www.uniqueautosports.com.au/Parts-Shop/400r-style-rear-bar-for-skyline-r33-gts-t-880.aspx
side skirtshttp://www.uniqueautosports.com.au/Parts-Shop/400r-style-side-skirts-for-skyline-r33-gts-t-870.aspx
i personally think the look of wheel arches on most cars look ugly unless it’s a full wide body or half wide body kit but I wouldn’t be able to install one of those myself so I’m just going to go for a nine wide body 400r I guess?
Yeah, these should be good and that front bumper looks alright to be honest.
The bottom lip is still a bit different to the real thing though. Just needs the center section fiberglassing/building up so it's flush with the rest to look like the real thing but if you like it, all's good.
The 400r bumper didn’t have a solid lip piece in the middle.
I have a 400r bumper on my r33
We cut the centre piece out and glasses over the little join marks to make it all one. If you do end up getting one look for indicators that for the little hole now as it took me sometime to find the right size. As for the wheel flares I’m wasn’t a huge fan of them as then did look silly when there put on a gts maybe on a gtr with wider guards it wouldn’t look bad
Maybe I'm misunderstanding but that's still not right either? Does like nice though.
The real lip looks like this.
On most reps, that center bit where I've drawn the red line on the first pic either goes in abit or is missing the center two vents entirely. The picture above is what the real thing looks like. The 400R bumpers also use same front indicators as a GTR.
cant get a new 400r bumper any where in the world, mine is as is a rep to, I cut the centre piece out as it looks dumb and added my own front lip. No the indicators as way different. Normal GTRs have that little duct insert with the indicator on it where the 400 has to sucken in holes where there indicator is mounted
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
