Hi there i pulled apart my cabin air filter to replace i cant seem to find one small enough one to fit. The old one that was in there already was one that the old owner has cut but wasn't a proper filter and has half fallen apart so cleaning it will be pointless
The part number AY684-NS002 cabin filter that mention in all the thread is way to thick to fit in mine the measurement of the old filter was 245mm x 95mm x 10mm thick I cant find anything that is thin enough to fit (10mm /1cm thick)
The video i posted below is similar to what I'm encountering that a person posted and for the life of me cant find anything suitable to fit
Skip to the 1 min 30 sec mark to see the filter tray assembly and you will see the issue
Edited by rahilp
1 minute ago, GTSBoy said:
Again part number AY684-NS002 wont fit it too thick
the video above shows what i mean
5 minutes ago, GTSBoy said:
Does that element actually have to be there? Is it part of a cold climate options pack or something? Piss it off and throw the fat filter in?
So these are the element things im not sure what they are
  • Like 1
So there are also two different parts on that Kudos page
AY684-NS002 'Pollen Only'
AY685-NS002 'Pollen, odour and allergen'
Interestingly enough - the diagrams for those are a little bit different:
AY684-NS002:
https://static.amayama.com/schemeparts/1567684350575_big.jpg
AY685-NS002:
https://static.amayama.com/schemeparts/1568682097546_big.jpg
But I think that's just a red-herring - as these filters are both the same size/thickness and fit the same.
Looking at your filters / those in the video - they're very very different.  From previous threads on this:
Which is far more consistent with:
https://4.bp.blogspot.com/-YgHVI_607sk/VuvbcXszgOI/AAAAAAAADyo/d_xmhh3_9sc6YyvOQSKmsFI0r-0pwSl2w/s640/NissanSkylineR34_CabinAirFilter_Manual1.jpg
Another interesting note - in the video, we see cabling or something coming out of the filter:
Which isn't consistent with other threads on this topic:
https://4.bp.blogspot.com/-v5OHYjMx3SE/WFEMJjszwlI/AAAAAAAAEcU/lA6gVFPF-tAJzrs5zTWNUVFAUEMLtjUJwCLcB/s640/skyline.meshur.com-R34-112.jpg
So - something is a bit different/weird here.   It may be you'll need a different housing to fit those style of filters.
I poked through diagrams and stuff and couldn't see any versions of filters like that - but maybe someone else has an idea or has seen this before.  The 'cold climate options pack' perhaps that another poster mentioned?
  • Like 1
Well, searching that part number online came up listed as 'Permanently out of stock'.
Googling for '503756-0120' definitely finds lots of images of these filters!
It also lead to this thread on gtr.co.uk (https://www.gtr.co.uk/threads/r34-pollen-filter.58381/#post-515069 ) :
Quote
Got the 2 white filters delivered today from Nissan as above, and guess what?
When I took off the panel as Ian describes above, the 2 filters inside are NOT white paper concertina type. They have electrical connections to them with what looks like an oval " electrical coil" in the filter housing and a black mesh on the other side. The housing for the 2 filters is exactly as ian has said on his site.
There is NO white paper type filter to be seen anywhere.
This filter looks like an anti static type which works by the use of the 12v system. These look mega expensive. So I have vacuumed them and put them back.
Now I have 2 brand new paper concertina type filters for sale, since my R34 GTR has this electrical type filter. I wonder if the white paper filter is for the GTT only?
The part number on these electrical type filters is 503756-0120 then underneath 96602.
As posted by R33 vspec
"I asked this a while ago, and got no reply. I had to do a bit of guess work myself!!!
Have you got the pollen filters from Nissan? I have the part# if you need it"
Did yours have these electrical type filters or the white paper ones as Ian describes on his site? If you have an R34 GTR, the why is your filter possibly diferent? Is this a UK spec mod for the R34 GTR?
I have taken some pics if anyone needs then to show these electrical filters. They look to be the same size as the paper ones.
The thread continues on talking about these 'electrical type' filters that use anti-static - and how impossible to get / expensive they are (and that was 2006). So I guess that answers what you have, at least.
This image shows apparently an extra bit in the AC display apparently relating to it:
https://s.auto.drom.ru/1/comments/95/94416.jpg
And there is some interesting translated Russian about possibly a Laurel and the operation of this particular style of filter - and that they're impossible to get / find.
Anyway, it sounds like if you're not happy with the filters you have now - it would be easiest to source the housing for the regular filters, and use those instead?
  • Like 2
Hey yeah i did find that Russian post, but yeah seems like their impossible to find, i wont give up just yet
Thanks for the help
  • 8 months later...
I went to change mine today and discovered i have these electrostatic ones too. When they're plugged in, i get that image on the climate control.  not sure if it means "filter is functional", or "clean filter".  I'm just going to give the filter part a wash and the static coil an air blow i think. EDIT: on second thoughts, the honeycomb filter is fibrous and looks like it wont stand up to a wash.  Interesting, the japanese writing on the side of the coils says "warning: do not disassemble, risk of electric shock". So i presume the control module for them bumps the 12V up to something much higher to create the ionisation effect!
Edited by ob1
Dude I hate when people create topics like this when you can just search ‘r34 cabin filter’ on google and get results. Cabin air filter.com.au has some for the r34 skyline. I bought it and installed it and it’s perfect
You obviously didn't read the post ....
  • Like 3
  • Haha 1
  • 2 years later...
For anyone out there looking for this part, ajudge is correct, these are micrguard puretron filters. Hard to come by, but Nissan sell a pair of thin filter replacements as a kit. Part number 27494-5L826 and can be ordered from USA or Japan. I paid $200 including postage from USA as they had stock. Nissan dealer wanted $300-$400 to order in from Japan.
See post below showing the kit and installation which also shows how to "reset" your filters (you'll need to google web translate):
  • Like 1
  • 2 months later...
I know this thread is old but it was a godsend for me. I thought I'd add my 2 cents for anyone trying to do this themselves.
I found the part on Amayama here and it was delivered within 7 days for < $100 AUD, breakdown is as follows:
  • Nissan 27494-5L826 - FILTER KIT, AIR PURIFIER & CARBON $65.97 AUD
  • Shipping: EMS International $32.79 AUD
  • Total $98.76 AUD
The video above was helpful, but I couldn't find a decent translation there for how long to press the reset etc. I found this guide to cleaning and replacing these which Google translated the page pretty perfectly.
Hopefully this helps someone struggling.
  • Like 3
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
