Good day guys, I'm currently working on a RB20DET that I have bought which was is in a pretty rough state. Just working on the motor and getting it all tidy.
I just wanted to know if anyone has extended there injector, water temperature, CAS wiring.Reason being I've bought a front facing plenum and wanted to tuck in the wiring loom to give it a cleaner look around the intake manifold area.
Also another thing is I'm going to be running 600CC Nismo injectors, ordered in some new plugs for the injectors as there different. But wanted to know if it does matter which injector plug goes where? or is there a specific order they plug in for each cylinder. My loom is currently out as I'll be extending it.
Attached is some photos of the engine bay before and after, Nty to RFB.
Cheers guys!
https://www.sau.com.au/forums/topic/480362-rb20det-injector-harness/
You're kidding right? Of course the order of the injectors matters. And of course you can extend your wires as long as you like. You'll probably need a longer accelerator cable as well. And I take it you have an aftermarket ECU??
