I have changed my front to evo with alpha omega racing so it is running evo 6 caliper and big routers
rear is stock and all corners rebuild with red stuff pads
fluid is dot 4 castrol racing and braided lines all around
i also bought brake stopper to stop master cylinder travel
i have a horrible softbrake but if pushed it will stop hard
hate the feeling though as front are 4 pot rather than 2
i am also looking to install evo caliper and 370z rear disc which is big brakes rear
i think that will make brake feel worse
would installing bm57 help?
seen various feedbacks people stating larger cylinder like bm57 makes it even softer
i don’t know much about master cylinder and what brake bias i would have but looking for some advice
it is on r34 gtt
https://www.sau.com.au/forums/topic/480381-bm57-master-cylinder/
Not possible unless you f**k up the bleeding.
What do the ratios of piston areas look like, Sumitomo caliper vs Evo caliper? Surely you did this research before you bought the kit.
I went from GTT brakes to an 8 pot KSport/D2/Attakd/Clone kit. I had similar symptoms to OP.
I noticed that people who had GTR's who upgraded to the brakes I bought said they had no brake feel issues.
I noticed that people who had GTR's who upgraded to Evo brakes and they said they had no brake feel issues.
The BM57 was a night and day difference, much firmer.
I got annoyed at it for many years. Just buy a BM57.
I did the Evo Caliper/Evo10/ Alpha Omega front conversion on my 34 over Christmas
From a few people I'd spoken to via a FB group, series 1 R34's had a BM44, and series 2 has a BM50
The BM50 has L5 cast onto it, the BM44 has L4 cast onto it
People with the BM44 had issues with the ABS not kicking in if you jumped on the brakes hard. Someone mentioned it was a volume issue
Mine with the BM50 seems to work great so far.
I had a similar issue about with a squishy pedal when I swapped to 33 brakes on my 32. I put the calipers on the wrong side, and couldn't bleed the brakes as the nipples were at the bottom :D:D Looking back that was pretty funny - check the bleed nipples are at the top
42 minutes ago, Unzipped Composites said:
HFM sell a BM57 master cylinder for around $150. At that price, how could you not?
BEWARE
I read bad things about the HFM one.
I also found out that Z32 BM57's are NOT the same. The knee point on the Z32 one will lock your rears much longer before they start to engage the fronts. The GTR ones are the ones you want. There's a R34 and R33 version. What's the difference between those? I have NFI. I got the R33 GTR version and the clip does work on a R34.
My R34 had nothing labelled on it's BMC, only a L6... which isn't L4 or L5!
IMG_20200228_184326.thumb.jpg.e666db7dc0f8606e8602b12c9c1bfc96.jpgIMG_20200228_184313.thumb.jpg.e5bc89a5f9b68374ace3422c2ae312cf.jpgIMG_20200228_184344.thumb.jpg.6cb75bc33bb37bebeb91d8a578d19059.jpg
Exactly the same here but on a GTST R33 - same front brakes, same soft pedal, same years of annoyance - the BM57 made a huge difference.
3 hours ago, Kinkstaah said:
BEWARE
I searched around and saw a few posts to this extent, but it was always reference to having read bad things, I never actually found a post written by someone who had a bad experience and what the issues were. There's a few good reviews on their website, not that those carry a lot of weight.
We'll find out anyway, I've ordered one for my car. Figured it was worth a punt.
The only thing I found from it (other than "I heard it was bad") was that it had the same bias as a Z32 BM57, which holds 50/50 split much longer (double) than a GTR one which splits to 60/40 much earlier.
In other words, expect more rear bias with the HFM/Z32 BM57. Doubt anyone would notice it unless you tried both back to back in different cars though.
If that is the only issue, then it isn't exactly an issue and more just something to be aware of and have in your mind if you get rear brake lock ups. Realistically, there's no saying standard distribution is more suited to a car than more rear bias. There's so many things affecting that, so standard bias on a modified S-chassis isn't necessarily the best anyway.
I would consider leaking and poor fitment as issues to beware of, but I shall endeavour to report back on this once the car hits the track again. If it's not poor quality, then it may still be a very good cheap option.
    • Don't do it if your gearbox box has already having syncro issues. The short hifter will put a greater load on them. If you must I remember Nismo did a shorter shifter, with the top part being physically shorter and the part that went into the gearbox was the same as stock. In saying that I've had a C's short shifter (I think) in mine for many years, which was given to me as the previous owner was not sympathetic to the gearbox. Thus forwarned I was careful and had to modify my normal changing style. You have to be super accurate with your clutch and shifts
    • Well, after a week of daily driving and having to crawl out between the wheel and the side intrusion bars. I got myself a quick release setup. I went with an NRG short hub and Quick Release with some cute heart cutouts on the pull tabs. Nice and matchy matchy with the rest of the interior accents I have going on.  The only downside is the total stack height even with the short adapter is longer than the old HKB boss kit. Luckily I had some adjustment left on the column so move the wheel away.
    • stock shifter with new bushes, springs and cup will improve it. Gktech do all the bits. The opinion as the years have gone on is the redline is not great in old gearboxes.
    • Hi all   what short shifter do you use on your skykine r34?   my synchronous does have a problem and i was getting huge delay and grinding sound between 2nd and 3rd, did put shockproof red heavy stuff and it is great now/ no issues   would in your view short shifter screw this up?   people seems to suggest/ use cube short shifter and there is standard and premium. Seen review of premium as much better and less play. Thoughts?
    • Yeah, there's a bit of a density and friability difference between pebbles and any of those other things. Silicone will definitely float in oil and so will be mobile enough to move around. Although, again, if it is upstream of the filter it really shouldn't go any further. I would only ever worry about silicone when it is in places downstream of the filter. Upstream of the pickup is a whole 'nother matter. We've all seen what that does. I have seen the most abominable crap settled out in industrial gearboxes, trunnion lube systems and the like, without any sign that any of it has touched anything in the machine. Just chilling in the bottom, waiting for the inevitable operator error that causes the whole machine to need to be dismantled for repairs.
