Hey people!
I've recently bought this 1996 series 2 R33 GTST sedan.
When the guy was selling it, he advertised it as 'm-spec'
A bit of study & I've realised there is no such thing. Rather 'M model'
But the body kit I have on my car still doesn't match up when I search online for it. Any info on what particular model I have (If any) would be appreciated.
I bought it for $9700, 111xxxkm, manual, complete stock, zero rust etc..  very well kept.
Thanks for reading!
  • Like 1
https://www.sau.com.au/forums/topic/480382-please-help-identify-my-r33/
As per the link, all R33 GTS25t are Type M. There was only a difference in R32 GTSt models.
Front bar looks like standard series 1 with foglights to me (in good conition BTW) but I'm not a bodykit trainspotter. BTW not factory dash, so unlikely to be correct KLM.
Plus, I like the stagea better anyway :)
Thanks for that info! I did find my exact model through the link posted above. It was just the front end that didn't make sense to me. But thanks to Duncan, I think I know whats going on.
As for the dash, I'm pretty sure its some shitty cheap sticker over the top. Looks very tacky, not lined up properly to the needle holder thing. The engine & condition reflect on the kms.. all original hoses, air filter, hose clamps. All had original paint dots on the hoses/clamps still. Can never be 100% certain these days though .
As for the stagea,  shes been defected ?
I also have a factory manual R33 Series II sedan in KR4 Silver - welcome to the sedan club.
The front and rear bars and the rear wing are standard for that model as are the fog lights/indicators.
As a Series II it will also have front turning lights that come on when the headlights are on and you use the indicators. The other challenge is that because it has Series II headlights it has a unique radiator support panel that is different to every other R33.
You are also right about the stickers over the factory gauges.
Thanks Victory! Never thought I'd be a fan of the R33 sedans, but this model just looks a lot nicer & sharp..? Opposed to the other 33 sedans anyway.
As for the gauges, I'd like to get them back to normal. Hoping thats a thing that can be done anyway. Otherwise someone local is selling a manual cluster with only 4000kms more than my own
    • You’re all still going on about track cars, he has said multiple times doesn’t intend to take it to the track,  just stick to what was said at the beginning and do the pump and ecu, it’ll get you enough for 230kw at the wheels and has enough poke to be fun for what you want it for
    • All of that is absolutely true. At any time in the history of these turbos the lottery has always been that it could die at stock boost treated exactly as the factory intended, or it could die when pushed to 10, or 12, or 14, or 16 psi, after a short time, or a longer time, or it could last seemingly forever. You have the combination of all the possible statistical (probably) normal distributions of manufacturing tolerances and quality outcomes, on top of the statistical distributions of failure modes (which might be normal, but are probably biased, like Poisson distributions). You get the lucky turbo and you can beat on it for years. You get the really unlucky turbo and it will crap itself as it rolls out of the factory gate. And every possibility in between. But you can definitely still kill the lucky turbo. It's just that most people didn't try, once they knew they really shouldn't try.
    • Maybe I have Stockholm syndrome but working on an M2 isn't that hard. Getting parts cheaply and quickly is hard, but getting parts same day isn't necessarily hard if you're willing to pay way too much for it at local dealers. There's a lot going on, you need to have a build of ISTA on a laptop and the right cable, if you don't have the mindset of "do it exactly right or not at all" you will probably start seeing cascading failures. Skylines are a little more tolerant in that regard. The car doesn't potentially trash itself if you bought the wrong oil filter like a BMW would. Or trash the entire cylinder head and potentially spin a bearing because someone took the anti-drainback valve out of the plastic oil filter cap. An M2 will also do just fine on track, zero oil starvation concerns, factory brakes are great if you change the pads for a high temp compound + flush with track-ready fluid.
    • The "ideal/formula" that used to be touted was death of the turbo is going to be caused by a combination of 3 things. Heat Speed of turbo (boost level you're pushing) Time   Basically, you can get away with high heat and high boost for short periods. But start doing long hard pulls, or circuit driving etc, and now you've increased time as well which will shred things. From memory when Adrian was drag racing he was running 17psi, on a stock turbo, and running insane speeds. But he also had other additives helping in the setup too. Some people have success at 14psi for a while, while others due to pushing the cars hard for long periods opt down to lower temps. But also, generate a lot of heat (let's say bad tune), for a long time, and you'll be okay, until you try to spin that little guy up slightly. It's the one advantage of dumping a lot of fuel in, you'll be reducing EGT a bit and helping with the heat portion of the above 3 areas.   And these days, stock turbos are that old that there's the possibility of just outright failures due to material age. I'm not shocked that even when used in factory spec that a stock turbo fails when 30 years old. It's a worn out "precision" "balanced" performance item, that's likely no longer precise, or well balanced
    • this... hence I said what I said previously, SMSP nights you see mainly Hondas, Evos, A90s, F80x and the odd VW. The 5 or 6 times I went, I only saw 1x R32 GT-R, and other than that I was the only one in a shit box Skyline.
