Hey guys, first time poster, could really use some help,
Spent some time doing this setup on my mates 34, one major thing was to keep all the stock stuff functionable an to fit with the aftermarket parts, (merely wanted a clean engine bay)
Its come time to start it, but won't start....
I didn't use the stock TB, I put on the 88mm the plenum came with an wired up a raceworks TPS sensor,
I have spark, I have injector pulse, could the elimination of the stock throttle body stop it from starting?
Thanks in advance
https://www.sau.com.au/forums/topic/480386-r34-25detneo-wont-start/
Got fuel aswell.
Doesn't have traction control, but yeah running stock ecu harness etc, just aftermarket bolt ons,
Is nistune the only option?
Not really fussed about an engine light at the moment just want to get it running
Edited by -R34GT-
The standard ECU thinks that there should be a TCS/ABS ECU present. If there is not, there will be fault codes.
The TCS/ABS CU, if it is present, will be freaking out because you have lopped off its throttle motor and position sensor. There will also be ECU fault codes because of this.
Nistune is the only way to make a standard ECU work nicely under this level of abuse. The Neo ECU is fairly obsessive compulsive about a few things.
8 minutes ago, KiwiRS4T said:
How big is that turbo? What ECU are you planning to run it with?
You say you have no ignition light...is  the starter turning the engine?
Engine turns over an everything performs as it should (minus the deleted TB) just doesn't start.
Its a gt35/40, now decided to go aftermarket ecu an loom, only made this post to see if anyone had a possible way to get the car to run an drive as it was with the factory ecu.
45 minutes ago, Ben C34 said:
The car should run, unless you have done something weird.not well but should run. You sure you wired that  tps correctly
Thats what I would have thaught, should atleast start an run, an yeah I double checked the tps wiring, have the voltage aswell,
Only thing that isn't hooked up is the original TB
And that is not going to work anyway, that is a switch not a sensor
Try plugging in old tps and traction control throttle body and see what happens. Trying random piggy backs is not going to help you.
Also what's the status of the iac set up?  Did that also fall victim the plan of having a "clean engine bay"
I tried plugging the old throttle body back in before doing the ecu, an it didn't do anything, no noise no movements no starting,
The hks was only put in to try simply cause I was being told that removing the throttle body an its components will cause the ecu to freak out, think it was mentioned in an earlier post too,
An the Iac is still there an functionable
    • Seemed to be good when Jeff owned it but they did a shit job on my car, probably worth a think before spending 10's of thousands of dollars where they might be cutting corners
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
