Started my car last week and almost all of my electronics wouldn't work, so I suspected the fusible link. The battery was relocated to the trunk in Japan (professionally by a shop). When they did that, they replaced the fusible link with a couple things.  There is a 30A fuse at the front where the battery was and there is a 200A 32V fuse on the positive wire right off the battery.  The 30A up front blew, so I replaced that and drove just fine. However, when I turned the car off, the lights went off. Checked the fuse and it blew again.  I haven't tried since, but I'd expect it to happen again.
I'm not terribly knowledgeable on the electronics of 90s Japanese cars, but I guess I'll be learning now.  Hopefully I can answer questions if there are any.
Nothing has been done to the car recently other than timing belt and water pump.
It might also be worth noting that the first blown fuse happened just with me backing out of the garage to work on some drywall, so the only movements/vibrations would be from idling.
https://www.sau.com.au/forums/topic/480397-fuse-blowing-when-turning-car-off/
I pulled out the head unit since it was the last change to the electrical system like 4 months ago and gave it another try with a new fuse.  Same issue.  However, I actually looked at the fuse this time and it blows on ignition.  All the electronics stay on until the engine is off.  So I guess the fuse holds on long enough for the alternator and then blows?  Goes to show how little I know about this car's electronics.
Edited by lukini
said something dumb
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
