what the? so you will have both banks feeding a gt42 and one bank feeding a gt30?
that is officially mental my guy. How did you come up with that? I'm all for thinking outside the square, but the square still exists.....
What engine is this for?
11 minutes ago, Ben C34 said:
Your plan for a 500kw ecotec, with a 2 turbo layout is interesting.
anymore details? Have you already turbo'd an ecotec or first time around?  It is a drag car i assume?
Na first time and street car low boost about 15psi high boost about 20psi
42 minutes ago, Bessel said:
What do you mean don’t get ya how can’t you?
Because....2 different sized turbos implies a sequential system. An inexperienced hobbyist setting up a sequential system from scratch sounds like hilarity. Toyota and Mazda spent millions on their systems and never really got it right.
So, I'll assume you're not doing a sequential system. I'll also assume you're not doing a true compound system, seeing as the turbos appear to be planned to be on opposite sides of the engine. And also because low boost and high boost numbers quoted appear to be about 1/4 of the values that you'd expect for compound.
So, maybe just two stage compression? In which case, the GT30 is mahoosivley oversized. Either that or the GT42 is. Well, at least one side of each of them, probably.
So, then I make a sensible suggestion of binning the additional turbo and putting an original M90 supercharger back into the Ecotec system and properly twincharge it. This actually makes a lot of sense because it will do what you suggest (fill the torque hole caused by the GT42) but.....if proper sequential is out of the question, then proper twincharging is also probably out of the question.
And all of those thoughts went through my mind prior to posting my first response, and it all seemed too hard, so I just copped out and made the post I did.
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
