The intent was to do the oil change and filter including dropping the sump and drilling the 3 x banjo bolts out to 2 mm .
Soooo dropped the sump [ which I might add was pretty clean inside !! With virtually no sludge and the pick up pipe was completely clean ,  explains partially why no turbo failure at 185,000K's ].
Anyhow decide to do the two inner sump banjo's first .
My 2 mm drill was pretty old so went out and bought 3 new 2 mm drills in high speed steel .
The banjo bolts seem to be high tensile but a good drill should be able to handle going from 1 mm out to 2 mm .
Well not so as I broke the drill when it was almost through !!
Not a total disaster but not real flash either .
Went out again and got some cobalt drills , marked out the center and drilled through the back of the banjo bolt and then punched the broken drill out no probs .
Drilled it to 2 mm then just welded up the 2 mm hole .
The other two banjo bolts were drilled out to 2 mm no probs .
As a note used a Z179A oil filter which is bigger than the Z436 and in fact the filter on it was a Z445 which is even smaller than a Z436 .
Go figure .
So oil change done with first mod with only a small hiccup.
  • Like 1
https://www.sau.com.au/forums/topic/480455-m35-first-mod-and-oil-change/
    • If it's for a SR20, make sure it's not the American Poncams, might as well call them Poocams. Had a set in a friend's car, all scuffed up after a few track days. Like the metallurgy Tomei USA used is junk. Went back to JDM OG Tomei Poncams, no issues till now.   Tomei USA is not the real OG Tomei.   Random rant over, fk the US of A, bunch of c u n t s.
    • Most of the industry in North America either runs on Siemens or Allen Bradley. I have two redundant S7-1500's on my desk right next to me for simulation. Siemens has been losing ground though since Stuxnet, as cybersecurity is a big thing. In my line of work that is federally regulated, you must by law have a cybersecurity management program in place and its audited and inspected every so often.  I work with Emerson PLC's daily (RX3i's) and have done large biogas/refinery projects with their DCS's. Their PLC's are somewhat OK minus the way they do PLC redundancy (You have to download on both PLC's separately every time you make a change )  As for their DCS's... you'll be limited financially first before anything else stops you. Costs are exorbiant at roughly 10x what it would cost you to do with any other system (e.g AB PAC).  1990's, those suckers are brand new haha! Kraft-Heinz (An old client when I use to work for an ESP) still runs Siemens TI505 PLC's from the mid 80's. Ohh how I don't miss working with those... you could only do a certain number of online downloads until it's "Change" buffer would be full and you would then need to go offline to do a full download. There was no warning of when this was coming up and it generally would happen when you would go in at 2am to make changes before production -_-.
    • Unfortunately, not only is that not the case, one of the main "Selling points" of safety over comms is they clearly state in writing that there's no need to segregate safety networks from non-safety networks. It always gets intermingled with everything else on an ICS/OT network.
    • Hello. I have an a31 cefiro but since I am in Turkey we have a CA20S engine. I did some research. Then I found that I can swap with a ca18 but when I heard that it has the similar substructure as the s13. I thought I can swap with an sr20 because the sr20 was used with the s13. So can I easily swap the sr20 on my cefiro or is it difficult?
