Hi,
see items below for sale - all items are used
All items are negotiable - can freight at the buyers expense  or pickup
Located in Griffith NSW 2680
Photos Attached
Standard R33 GTR Turbo set - includes manifolds and heatsheilds, only has 1 stainless down pipe. Minimal shaft play
Manifolds do have holes in them due to EGT sensors being fitted previously - one hole per manifold
Looking for $120.00 for the pair
R32 GTR Drivers side A/C Vent - was removed to fit a gauge
$25.00
Standard RB26 Valve Springs with Retainers
Came out of a Nissan reproduction engine so not many KM's on them
$40.00
Standrad RB26 Camshafts intake and exhaust
Came out of a nissan reproduction engine so not many KM's on them
No Picture
Looking for $80.00 for the pair
R32 GTR A/C Condesnor Fan
Tested Still in working order
$65.00
CUSCO Radiator Cooling Panel R32 GTR
Like New , has a few minor scratches and a rub mark in the RH corner
$45.00
R32 GTR Speedo Cluster 340KM
Bad Points - KM Count has gone crazy/ Not reading correctly , speedo works fine and Front Torque gauge dosent Work
$70.00
Edited by nismo32gtr
https://www.sau.com.au/forums/topic/480459-gtr-parts-turbos-speedo-etc/
  • 3 weeks later...
  • 4 weeks later...
Also i have the below for sale
R32 GTR Passenger Side Reverse Light $25.00
Good condition no cracks - will come up good with a cleanup
R32 GTR Headlights LH & RH $100.00 for the pair
Good condition usual wear and tear for there age - black paint on top coming away and rear bulb boots cracked
Grill Brackets NOT Damaged
These are NOT  N1 they are the standard Projector style 1989 units
R32  GTR Centre Console Gauge Assembly $80.00
Was in working order when removed
Cant upload photo's at the moment - but i can supply upon request
4 hours ago, Robzilla32 said:
I will take the headlights please if you can ship to Melbourne
Hi Robzilla32
Yes i can ship to melbourne at your cost - i would say they would be around $25-$30 to post
  • 4 weeks later...
    • For sure the later RB26 variants had a different setup (6 cam voltage sender?), but the RB25DE/DET share the same ECU pinout/PCB footprint, and at the ECU plug it ends up being 'throttle sensor in' & 'throttle sensor out' (to A/T TCU) ...you stick a multimeter on these pins and you'll find them directly connected (0 ohms) ; I had an pair of Nissan ECUs on the bench long ago, and I noticed this throttle sensor in/out link, actually linked to an op-amp ...which was unpopulated on the NA board, but present on the T board and I went 'ah-ha!' in some moment of clarity... ...it wouldn't surprise me if they changed strategy here though (in the software and actual monitoring of this signal), because they did with other stuff (A/T signals).. and 0.45v as a trigger point makes sense, as that's what the external TCU units expect at idle ; kudos, thanks for that insight...I suppose it boils down to whether or not Consult can display real time data of that signal's voltage... ...in any event, it presents the same target...ie; rotate TPS unit to achieve 0.45v to suit both ECU&TCU, and where do you goto from there? Just disconnect TPSwitch connector and/or that plus TPSensor connector....or do you go for the throat and disconnect IACV solenoid and see if it still stalls? (probably throws a recoverable fault code and goes for default idle strategy?)...
    • I’m also conscious that e85 is slowly being phased out. Not all United’s have them anymore. Can’t take the risk of being low on petrol and assuming the servo will have it.
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
