Hi,
see items below for sale - all items are used
All items are negotiable - can freight at the buyers expense  or pickup
Located in Griffith NSW 2680
Photos Attached
Standard R33 GTR Turbo set - includes manifolds and heatsheilds, only has 1 stainless down pipe. Minimal shaft play
Manifolds do have holes in them due to EGT sensors being fitted previously - one hole per manifold
Looking for $120.00 for the pair
R32 GTR Drivers side A/C Vent - was removed to fit a gauge
$25.00
Standard RB26 Valve Springs with Retainers
Came out of a Nissan reproduction engine so not many KM's on them
$40.00
Standrad RB26 Camshafts intake and exhaust
Came out of a nissan reproduction engine so not many KM's on them
No Picture
Looking for $80.00 for the pair
R32 GTR A/C Condesnor Fan
Tested Still in working order
$65.00
CUSCO Radiator Cooling Panel R32 GTR
Like New , has a few minor scratches and a rub mark in the RH corner
$45.00
R32 GTR Speedo Cluster 340KM
Bad Points - KM Count has gone crazy/ Not reading correctly , speedo works fine and Front Torque gauge dosent Work
$70.00
Edited by nismo32gtr
https://www.sau.com.au/forums/topic/480459-gtr-parts-turbos-speedo-etc/
  • 3 weeks later...
  • 4 weeks later...
Also i have the below for sale
R32 GTR Passenger Side Reverse Light $25.00
Good condition no cracks - will come up good with a cleanup
R32 GTR Headlights LH & RH $100.00 for the pair
Good condition usual wear and tear for there age - black paint on top coming away and rear bulb boots cracked
Grill Brackets NOT Damaged
These are NOT  N1 they are the standard Projector style 1989 units
R32  GTR Centre Console Gauge Assembly $80.00
Was in working order when removed
Cant upload photo's at the moment - but i can supply upon request
4 hours ago, Robzilla32 said:
I will take the headlights please if you can ship to Melbourne
Hi Robzilla32
Yes i can ship to melbourne at your cost - i would say they would be around $25-$30 to post
  • 4 weeks later...
    • had 4 weeks off over xmas and well did some stuff to the shed and BRZ, well short of is I don't work full time in supercars anymore as of yesterday.........
    • Did you get any down time over Christmas, or have you had any since to play with this? Or have you given up and are trying to get yourself a second hand V8SC instead?
    • A random thought I had just before I hit "Submit on this post". If brake fluid, in a container in my garage that has never been opened goes bad after 18 months, why can I leave it in my car for 24 months in an "unsealed container"... Secondly, some other digging, and brake fluid manufacturers seem to be saying 5 year shelf life... Me thinks there line on 18 months for an unsealed bottle is pretty much horse shit marketing spin. Kind of like how if you drive a car and don't run a turbo timer your turbo and motor will die horribly...   Where I started on this though... Someone (me) started down a bit of a rabbit hole, I don't quite have the proper equipment to do Equilibrium Reflux boiling per the proper test standards. I did a little digging on YouTube, and this was the first video I found on someone attempting to "just boil it". This video isn't overly scientific, as we don't have a known reference for his test either. Inaccuracy in his equipment could have him reaching the 460 to 470f boiling point range in reality. In the video, using a laser temp gun, he claims his Dot3 that's been open in his florida garage for over a year gets to about 420 to 430 fahrenheit (215 to 221c) Doing some googling, I located an MSDS for that specific oil, and from new, it claims a dry boiling point of 460 to 470f. Unfortunately they don't list a wet boiling point for us to see how far it degraded toward its "wet" point. While watching it I was thinking "I wonder what the flash point is..." turns out its only 480f for that specific brake fluid....   As for testing the oil's resistance, I might not be able to accurately do that unfortunately. Resistance level will be quite a LOT higher than my system can read I suspect based on some research. However, I might be able to do it by measuring the current when I apply a specific voltage. I won't have an actual water % value, but I'll have some values I can compare between the multitude of fluids. I'll run some vague calculations later and see if I should be able to read any reliable amount of current. These calcs will be based on some values I've found for other oils, and see how close I'll need my terminals together. From memory I can get down to 1pA accuracy on the DMM. I don't think my IOT Power Tester has any better resolution.
    • No, with a twin plate clutch flywheels and clutch pressure plate/friction disks go together. Only clutch where that isn't the case is the Uniclutch but they currently don't make a pull version for the Getrag R34, just some other cars. Personally the flywheel is as light as I'd want it to be. It already drops revs faster than I want to shift normally and I blip the throttle again to rev match on upshifts.
    • Are there any other lighter flywheels that can be used with nismo coppermix twinplate system? Id like to gave the revs pick up faster than oem
