I’m an R32 GTR guy, but I’m looking for a runaround and found a 2002 AR-X Four NM35. It’s an auto, and appears unmolested(which is perfectly fine by me). 110,000km on the clock... whether that’s verifiable or not remains to be seen. What issues do these cars usually present? Anything in particular to look for? If it was an 260 RS Autech I’d be way more familiar with the underpinings.... I’m not at all across this AWD AR-X!
Come at me with info!
Rust, everywhere, including inside A-pillar.
Turbo making dyson noise, Attessa light, noisy vct solenoid.
Sluggish gear changes
Apart from that, ARX suppose to sit a bit higher than NM35, comes with bodykit (flare), standard rear viscous lsd.
Thanks; this fits in with what I was thinking so far!
Are you planning to keep it stock? If so I would look for a VQ35 model which has the same power output as the VQ25DET but without the turbo to worry about or the 25's propensity to wear out the timing chain around 200,000km.
Yep, stock is well preferred. I’d LOVE. 260RS, but we all know what happens there, LOL!
    • The cam I am actually putting in (a few posts up) is actually smaller than my current one. At least duration/overlap wise. All the chop stuff I hear just sounds like an engine running badly, because it is. I then envision driving it around in 1st gear and being massively sad about it bucking to the beat of said chop. There is an idle video of someone with a similar cam floating around the internet, but mine is a custom cam (so is his) so it'll never be the same, plus the fact exhausts are entirely different. What I want to do is put some bullet mufflers/race mufflers in to replace a couple sections straight pipes that currently replace the two extra cats that I don't need. But this is even further down the line!
    • I can tell you now, when the bracket that the little hydraulic ram attaches to snaps, with a subframe, and V8 from an AMG C63 on it, it sounds like someone letting shotgun off right beside you. It leaves your ears ringing, and a huge thankfulness that you never ever put a body part under something heavy that's only supported by a hydraulic lift...
    • Still not a guarantee fix. I used a high quality butyl-mastiq (the black goo that's not really silicone nor polyurethane, same stuff they use from the factory that just spreads out like melty cheese), and I still get lots of water on both sides of the trunk when raining or washing the car. I also suspect the factory spoiler rubber gasket might not be sealing well, so I'm thinking of adding a thin layer of grey silicone around the bolt holes on both sides and see if that's where it also leaks from. The biggest issue is that these cars don't come with a drain hole on each side like other coupes and hatchbacks.
    • I hate it, but maybe he could paint it Monster jam style and call it...godzilla?
    • Would seem to me to be appropriate to go GTR style bar. There are options with and without N1 vent holes, with the GTR lower lip integral (because FG copy). https://justjap.com/search?q=r32 bumper
