Won’t be able to adjust rev limit and honestly I never get near it due to my fear of losing the oil pump. At 5k rpm boost builds with no issue no hiccups just the fact that it is a thousand rpms slower than where it should be. It’s a .82 ar so really nothing crazy. I’m going to unplug wastegate signal and go for a drive keeping an eye on boost and how fast it builds. If it behaves the same then my guesses would be cam timing is off or engine is tired/ low compression. It gave me no issues on stock turbo and manifold on 12psi.
  • 4 weeks later...
Something so stupid that I hadn't considered until I found someone with the same problem. f**kin gear ratios. how bad would they effect spool up? With a final drive of 3.9 and thick tires in the back making my effective around 3.8 that would definitely cost me 500rpms in spool right? Found someone with the same setup same power but .63 hotside spooling up at 6k. Difference between me and him is 3.5 final drive and 295 tires making his effective ratio 3.3. Could this be the answer or should I keep looking into it?
Higher numeric final drive (shorter gears) would affect the RPM you spool by because the engine will reach higher RPMs sooner. But if you were to do a time to torque/boost measurement you would find it to be faster because the engine is getting up to an RPM where it can spool the turbo sooner. You can play games with dyno load to do this, it's effectively brake boosting.
    • To be fair passengers who aren't silly and have been in proper fast cars have often been pretty impressed once you hit 4th gear
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
