Hello!
Lucky me, I’m mostly asking this question to see if I should stop driving my car or if it’s okay.
As I was bringing the front of my car off the jack, the frame slipped, and my jack pushed my radiation up up up up and cracked my fiberglass hood. It also bent my harmonic balancer pulley on my RB25DET where the power steering belt goes just a little bit, looks more like a scrape but does have a little bit of a bend.
Should I be concerned about the pulley?
I have driven for a day, did a couple of highway pulls in 3rd, cruises, everything feels okay, maybe a little shaky but it could be my own paranoia! Haha.
Thank you!
26 minutes ago, GTSBoy said:
I wouldn't be worried about that little bend much. I would be worried about what other effects there might have been from dropping the weight of the car onto the balancer/crank as a whole might have done.
Well, the radiator has a huge dent on the bottom where most of the weight went. Plus, my radiator has metal brackets at the top bolted to the chasis to keep it from moving so that also took some weight.
I read online that 3rd gear carries the most load and if the hormonic balancer is bad then that’s when I would experience some symptoms buuuut everything seems fine.
But yes, I suppose time will tell if something internally went wrong. I freakin hope not, I just rebuilt it! Yikes!
What?
Rev the car to 1500ish and look out for a wobble in the steering wheel and gear knob when stationary. The balancer wobble of death. You could try to fix it but pay close attention to the keyway on the crank snout. If you've damaged that no matter what you do it will always come back loose. Fingers crossed for you.
Edited by trel
I'd be removing the harmonic balancer and setting up a dial gauge and checking the crank snout for any run out.  Then throw the HB away and put a new one on just for peace of mind...damn sight cheaper than using it and waiting for/watching the action.
I revved up my engine and the steering wheel doesn’t wobble at 1500+ just vibrates the same as if it was idling.
On the shift knob, there’s more vibration there when the car is revved up but that might just be normal for my car.
I decided to remove the engine and inspect the crank, bearing, and all that good stuff just to be sure. I’ll update this forum once I have more information about the damage or no damage.
  • 4 months later...
Okay! It’s been a few months and the car is back on the road!
That accident I had completely threw the sixth beating out of line and was very quickly causing damage to the crank.
it has been rebuilt again. :)
  • Like 2
  • Sad 1
    • $53.35 and a double din Pioneer head unit that I have...
    • Put a camera facing your dashboard so you can film the gauges. Head out to a straight but of road, and filming it as you go from a stand still at wide open throttle to as fast as you can/feel comfortable doing. Then film the dash board as you for example accelerate like normal onto a freeway. This will give us an indicator from Speedo of your expectation of slow, and will give us the rpm reading too to see if it's shifting. (Auto still has tacho from memory)
    • Buy yourself the cooling system pressure tester. Being able to pump it up, and have a gauge on it, AND have a cold engine makes it much easier / practical to diagnose. Additionally as the engine isn't running, you can listen for pin hole leaks as well as watching if pressure drops away. In addition, you can pressurise and while doing so, watch all the little rubber hoses. Some fail very brittle, and will just leak, while others can end up very soft and bulge. While a bulging hose isn't necessarily leaking, one of those small ones starting to stretch / expand in a bad way is an indicator that you'll be looking to replace that one soon   Depending on if this is a project car, or you'll be dailying it in the summer months would alter how I'd be most comfortable with driving the car and how I'd replace. If you're planning to use it as a daily, with no backup, I'd pull the engine, and replace all the external oil/water lines in one big swoop. At the same time do the timing belt, water pump, tensioners etc. Do not open the engine at all. We just want to replace all the things that are inexpensive as a single item, but a PITA when they go. By doing the above, you've made the car from a bunch of age related issues more reliable. If it's a project, and you like swearing while trying to reach into dirty hard to reach places to replace a single hose that may or may not be the leaky one. Just replace the leaking/bad ones as they need it. If it's a project and you'd rather swear at the car once and enjoy it as much as possible, then refer to the process I mentioned in how I'd want to do it if it were a daily. However, the approaches above do come down to how much spare pocket change you have. Pulling the engine and dropping over a thousand dollars on parts, may not be practical for you. Oh, if engine outing, I'd replace as many silicon/rubber inlet joiners as possible too.
    • Yeah, they're pretty dumb though...ie; they'll throw a solenoid error if the solenoid is dead, shorted, wiring is open circuit, or even if the driver transistor has failed (they can't self-diagnose much, they can only test inputs/outputs)... but if you wanted to try, I believe it's this protocol....(uses a long pulse indicator with short pulse counter)...
    • Yeah I'll do what I can without taking off any major parts for now. If it becomes clear I won't get far with the engine in the car I'll have to think about the next steps. I am not too stuck on keeping everything 100% OEM, if there is better solutions, like converting most lines to braided with AN adapters, I'd rather do that than buy overpriced new "shit" parts.
