Hi!
I have had the pleasure of having my high pressure line on my power steering start leeking.
Tried to so a quick fix to no help, and since stagea parts arent easy to come by where i live, i was wondering if anyone have swapped out the oem with AN connections and hose?
8 hours ago, KiwiRS4T said:
What's a servo?
Supose to be power stearing, but i forgot that power stearing was the word when i wrote it, and servo is what we use to call it and sounded rigth in my head, gonna try to get the post fixed
If you don't have access to Nissan parts and can't wait to source them from Amayama  etc then a hose doctor (hyraulic hose repair) such as ENZED, Hydraulink (don't know what brands you have  where you are) should be able to make one for you.
  • Thanks 1
The w8 i can handle, the 350$ + shipping +25%toll i can not ?
Therfor i wonderd if anyonr had mad eout of AN so i coud just make it myself ?
How could you make it out of AN fittings when there are not AN fitting on the PS pump or the rack? You have whatever fittings Nissan put on there. But these will just be a hydraulic fitting of one sort or another, so if you took the PS line into a hydraulic hose doctor place, they should be able to knock something up.
Ther is adapter that can be used mostly, on the pump side is a normal banjo so not hard to find
On the rack side is a bit wors but shoud be posible if i can figure out the siced :)
6 hours ago, WR33KD said:
Im changing all my lines to AN high and low pressure side. It can be done
Cous you tell me witch firings are in the rack? Or at least what treada and atuff so i can irder some and try ?
Do you alsoe kbow if the sensor conekted in the presur eline is any inportant? ?
You need to rack fittings that go to an6 and one pump fitting that goes to an6 then an8 from pump to reservior. Hardest part it making sure your long enough so a lot of measuring
AN hose and fittings should not be used for hydraulic applications like power steering. Get a proper hydraulic hose made up - it will probably cost less than trying to do it with AN hose and fittings.
How so? They are strong and can withstand hige presure, as long as you buy the corekt hose :)
The price wil probebly be more expensive if ingo to somone ro make ir due to wher i live, alsow they most likly wont do it because it is car related and stearing related.
First world country that is smaller than most states in Australia. Just drive to a place that can build you a line.
I can think of 15 places within a 1hr drive of where I live that will build a power steering line for me. All of them industrial hydraulic places. You should tell your weenie TUV koolaid drinking Euro regulators to shut up and just let people make a hydraulic hose.
  • Haha 1
More expensive than what? Mobile hydraulic hose doctors make lines for $million machinery including huge excavators and small forklifts. They make brake parts, steering parts and more for all kinds of vehicles. Do you know how much pressure your steering system can experience momentarily? A professional is going to do a better job than you can  and has the gear to do it.
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
