Hi!
I have had the pleasure of having my high pressure line on my power steering start leeking.
Tried to so a quick fix to no help, and since stagea parts arent easy to come by where i live, i was wondering if anyone have swapped out the oem with AN connections and hose?
8 hours ago, KiwiRS4T said:
What's a servo?
Supose to be power stearing, but i forgot that power stearing was the word when i wrote it, and servo is what we use to call it and sounded rigth in my head, gonna try to get the post fixed
If you don't have access to Nissan parts and can't wait to source them from Amayama  etc then a hose doctor (hyraulic hose repair) such as ENZED, Hydraulink (don't know what brands you have  where you are) should be able to make one for you.
  • Thanks 1
The w8 i can handle, the 350$ + shipping +25%toll i can not ?
Therfor i wonderd if anyonr had mad eout of AN so i coud just make it myself ?
How could you make it out of AN fittings when there are not AN fitting on the PS pump or the rack? You have whatever fittings Nissan put on there. But these will just be a hydraulic fitting of one sort or another, so if you took the PS line into a hydraulic hose doctor place, they should be able to knock something up.
Ther is adapter that can be used mostly, on the pump side is a normal banjo so not hard to find
On the rack side is a bit wors but shoud be posible if i can figure out the siced :)
6 hours ago, WR33KD said:
Im changing all my lines to AN high and low pressure side. It can be done
Cous you tell me witch firings are in the rack? Or at least what treada and atuff so i can irder some and try ?
Do you alsoe kbow if the sensor conekted in the presur eline is any inportant? ?
You need to rack fittings that go to an6 and one pump fitting that goes to an6 then an8 from pump to reservior. Hardest part it making sure your long enough so a lot of measuring
AN hose and fittings should not be used for hydraulic applications like power steering. Get a proper hydraulic hose made up - it will probably cost less than trying to do it with AN hose and fittings.
How so? They are strong and can withstand hige presure, as long as you buy the corekt hose :)
The price wil probebly be more expensive if ingo to somone ro make ir due to wher i live, alsow they most likly wont do it because it is car related and stearing related.
First world country that is smaller than most states in Australia. Just drive to a place that can build you a line.
I can think of 15 places within a 1hr drive of where I live that will build a power steering line for me. All of them industrial hydraulic places. You should tell your weenie TUV koolaid drinking Euro regulators to shut up and just let people make a hydraulic hose.
  • Haha 1
More expensive than what? Mobile hydraulic hose doctors make lines for $million machinery including huge excavators and small forklifts. They make brake parts, steering parts and more for all kinds of vehicles. Do you know how much pressure your steering system can experience momentarily? A professional is going to do a better job than you can  and has the gear to do it.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
