Here's what I use on the 32 and 33 gtr. Supercharge MF40B20L Goldplus series is a good choice if you want to keep the standard size. I have to use a 40 in the 32 as I have too much shit around that area to run anything bigger. In my 33 it's a 55. The MF40B20L is 390cca and compact, this is the standard physical size for 32 and 33 GTR. The Century MF40 version by comparison is 330cca. MF55B24L is a better choice as they are 490cca, but they are wider. These seem to be my picks as they best available under $200.
After that you go all out with the Optima AGM Yellow tops. By far the best, but approaching $400. They are available at 700cca plus and people have reports of batteries lasting 7 years or more. I don't see the point as Supercharge Gold plus is 40 months no questions asked replacement warranty.
The MF40 is the standard factory size and MF55 is actually the Nissan cold weather pack upgrade size, hence why you can fit both. Same depth and height, just a 55 is wider as mentioned above. So if you can run at least a 55.
More importantly than any battery though is get a Ctek, especially if it is not a daily driven car, which is most GTRs. Need a good maintain charger.
  • Like 1
@GTSBoyIs that true - as in outright replacement, or is it just the pro-rata
Complete replacement, as in within 40 months of purchase if it fails, full new battery on Gold Plus series. My old man even did one literally at about 39 months from purchase recently on the XR6. I can say I have done it about 3 times across all of my car's ever. The dealer stamps it on purchase, and they are very adamant about retaining and supplying your original receipt upon replacement, but apart from that, yeah no problemo. Sometimes they'll want it overnight to prove it, but if it is stuffed its stuffed and they'll see that.
Cool, you realise that it is the right positive terminal instead of the left, which is standard in a GTR ? It does have the correct small terminals though.
CCA is also 450 on a 38ah battery.
Does not sound like good value unless it does last you at least 5 -  6 years, as that is the price of 2 x MF55B24 with 490cca and 50ah. I am yet to justify the price of Optima. Happened to have this in the ute for reference:
There is absolutely no question they are good, all the serious 4WD and off roader guys run them here. I just couldn't justify $300+ for 38ah and 450cca.
Post back in 5 years and see if it's still going strong ?
You really don't get what I'm saying do you ? 38ah is the smallest, most piss weak size battery for any car, regardless if it is a $100 or $1000 battery. As I said above 50 minimum is generally the go for any car now, and paying that much for such a small battery just seems silly. Anyway sounds like you went and got one so hope it lasts ok.
When people have been going through the trouble of going to an Optima yellow top they go for the big ones and make them fit for a massive increase in CCA and AH, or to mount them laying down as they are AGM.
  • Like 1
On 01/06/2020 at 3:58 PM, GTSBoy said:
NS70MF
650 CCA.
This is essentially the physically largest and largest capacity battery you can drop into the stock location.
Hey if this is in your 32 , next time you need a battery the Supercharge Goldplus equivalent is the MF80D26. Same dimensions but 80AH and 720cca ?
  • 1 month later...
Just an update, took your advice bk and went the supercharge gold plus? Starts awesome and very reasonable price. Went the 55B24.
Hey Ben,
Awesome insight into the topic.
Quick question, what would be involved with swapping over to Optima Yellow?
  • 2 years later...
    • Good news!!! Changed the O ring today and I’ve got the “pssshhhh” back when I open the fuel cap 😂🙌🏼🙌🏼 It was 100% the O ring because that bloody thing was inside the fuel tank 😂😂😂😂😂 Fitting new fuel pump was a pain as always since the DW is a bit longer than stock. But she’s running!!! ❤️
    • PWM quite literally just chops the ful 12V voltage on and off at whatever duty cycle you're running it at. If you're running it 100%, then it is on full voltage all the time, same as if there was no PWM. If you run it at 50% duty cycle, it is only seeing the full 12V half of the time. This is broadly equivalent to running it at 6V. But the crucial difference is that motors (and a lot of other loads) don't like being powered at low volts. They will either fail to start rotating, or draw a shit ton of current, or other undesirable things. But if you give them the full volt, and then a short period of no volts, and then some more full volts, then the times when they are seeing power they are seeing all the voltage, and they are happy. But you get the performance out of them as if they were only seeing that fraction of the full voltage. It is not really easy to answer your question about what flow you will get out of it at 50% duty cycle. I can tell you that it is not as simple as you think. For a start, that 460 L/h pump is not going to flow 460 when you're on boost. When you're on boost you will be somewhere down the sloping part of that red line. If you have 15 psi of boost, then the pump can only deliver about 95 gal/h, which is <380L/h. So your simple 50% on 460 = 230 wasn't going to work anyway. But also, it won't deliver 50% of 380 either, because when you devolt or PWM trim th epower being fed to the pump, it is not able to deliver flow or pressure in the same way. 50% duty cycle will probably produce <50% of the full voltage flow. The way to find out what duty cycle you need to run it at at low load (ie, at idle) is to idle it and turn the DC down until you start to lose fuel pressure, then turn it back up above that with some extra for safety. And then you do the same thing at full load, in case it doesn't need anywhere near 100% DC. And if you're careful/caution/prudent, you will also do it at a couple of loads in between so you can shape the DC map against load. It might not be linear between the two end points.
    • Man that dinner was such a long time ago....2010! I would only replace the rubber coolant lines with silicone these days; cheap, readily available and will last for ever. You will need new hose clamps though eg https://justjap.com/products/cooling-pro-silicone-engine-heater-hose-set-black-nissan-r32-gtr-rb26dett
    • I wouldn't look too hard at what they did with the R32 GTR in endurance racing in Australia... Lots of things weren't actually available from the factory in the way those cars ran them... Japan also followed what Fred Gibson was doing here with some of there endurance cars in Japan... Australia is also the reason for things like the Brembo brakes, and the change in the gearbox... And quite a few other tricks they used to pull. There's a few other SAU peeps still on these forums that will have heard the stories direct from Alan Heaphy, Fred Gibson, and Jim Richards when we were lucky enough to have a great dinner with them
    • For all the talk of "these parts are junk" I generally recommend OEM because it's really not as bad as claimed. I have never seen or heard of a case like the N63 where the oil returns completely clog with coked oil for example in ~10 years or less. Would it be nice if it were a straighter path? I guess, but most modern cars use a scavenge pump instead of a pure gravity return. Also the factory lines that would be relatively simple to convert to braided are generally speaking hardlines from the factory. I would consider braided line to be a regression, not an improvement. It's also been engineered such that all the hardlines have appropriate strain relief where needed. There's absolutely room for improvement, for example the HKS advantage heritage intake piping shows just how much can be done to make the turbos fight each other less in OEM twin turbo configuration and reduce compressor surge but it's rarely a simple/straightforward process. I recommend looking at what the group A/N1 cars did, generally speaking the changes they made were necessary and proven in endurance racing.
