Here's what I use on the 32 and 33 gtr. Supercharge MF40B20L Goldplus series is a good choice if you want to keep the standard size. I have to use a 40 in the 32 as I have too much shit around that area to run anything bigger. In my 33 it's a 55. The MF40B20L is 390cca and compact, this is the standard physical size for 32 and 33 GTR. The Century MF40 version by comparison is 330cca. MF55B24L is a better choice as they are 490cca, but they are wider. These seem to be my picks as they best available under $200.
After that you go all out with the Optima AGM Yellow tops. By far the best, but approaching $400. They are available at 700cca plus and people have reports of batteries lasting 7 years or more. I don't see the point as Supercharge Gold plus is 40 months no questions asked replacement warranty.
The MF40 is the standard factory size and MF55 is actually the Nissan cold weather pack upgrade size, hence why you can fit both. Same depth and height, just a 55 is wider as mentioned above. So if you can run at least a 55.
More importantly than any battery though is get a Ctek, especially if it is not a daily driven car, which is most GTRs. Need a good maintain charger.
  • Like 1
@GTSBoyIs that true - as in outright replacement, or is it just the pro-rata
Complete replacement, as in within 40 months of purchase if it fails, full new battery on Gold Plus series. My old man even did one literally at about 39 months from purchase recently on the XR6. I can say I have done it about 3 times across all of my car's ever. The dealer stamps it on purchase, and they are very adamant about retaining and supplying your original receipt upon replacement, but apart from that, yeah no problemo. Sometimes they'll want it overnight to prove it, but if it is stuffed its stuffed and they'll see that.
Cool, you realise that it is the right positive terminal instead of the left, which is standard in a GTR ? It does have the correct small terminals though.
CCA is also 450 on a 38ah battery.
Does not sound like good value unless it does last you at least 5 -  6 years, as that is the price of 2 x MF55B24 with 490cca and 50ah. I am yet to justify the price of Optima. Happened to have this in the ute for reference:
There is absolutely no question they are good, all the serious 4WD and off roader guys run them here. I just couldn't justify $300+ for 38ah and 450cca.
Post back in 5 years and see if it's still going strong ?
You really don't get what I'm saying do you ? 38ah is the smallest, most piss weak size battery for any car, regardless if it is a $100 or $1000 battery. As I said above 50 minimum is generally the go for any car now, and paying that much for such a small battery just seems silly. Anyway sounds like you went and got one so hope it lasts ok.
When people have been going through the trouble of going to an Optima yellow top they go for the big ones and make them fit for a massive increase in CCA and AH, or to mount them laying down as they are AGM.
  • Like 1
On 01/06/2020 at 3:58 PM, GTSBoy said:
NS70MF
650 CCA.
This is essentially the physically largest and largest capacity battery you can drop into the stock location.
Hey if this is in your 32 , next time you need a battery the Supercharge Goldplus equivalent is the MF80D26. Same dimensions but 80AH and 720cca ?
  • 1 month later...
Just an update, took your advice bk and went the supercharge gold plus? Starts awesome and very reasonable price. Went the 55B24.
Hey Ben,
Awesome insight into the topic.
Quick question, what would be involved with swapping over to Optima Yellow?
  • 2 years later...
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
