I recently picked up a 94 gts25t about a month ago now and within the last two weeks the car has developed an issue within the rear end of the car during low speed corners (less than 20-30kph) but most noticeable when turning onto an intersecting road or backing out of the driveway and pulling forward. what its doing is hard to describe but to me It almost feels as though the rear diff is binding up or SIMILAR to what driving a car with a welded diff feels like. The part that's messing with me is any corners or curves anywhere above that 20-30kph mark the car doesn't do anything strange. there are no noises, vibrations, or clunks from the rear end. is it possible that something like this could be caused by the Hicas rack? this is my first skyline and really don't have any reason to believe I have a bad Hicas unit but again I'm new to skylines and still relatively unfamiliar with the Hicas system. I've been in a handful of vehicles with bad diffs or diffs on their way out, even rebuilt my fair share. its usually pretty apparent when you've got a bad diff.
I did dropped the fluid the other day and there was no evidence of metal shavings in the fluid whatsoever even fished a magnet around the bottom of the case with no chunks or shavings on the magnet.
I've been trying to search for even a similar issue to mine since I first experienced it with absolutely no luck.
im lost as to what my issue may be and hoping someone can help shed some light on it.
thanks in advance!
-Joe
Edited by joebresson
https://www.sau.com.au/forums/topic/480519-rear-end-bind/
No.
Question. What diff does it have in it? Stock VLSD shouldn't act the way you describe, but if some arsehat has shimmed it, then it could act incorrectly. If it has a mechanical LSD in it, then the behaviour you describe sounds typical.
Note that it is important that you know what sort of diff you have in it, because stock VLSD does not want LSD oil (wants normal diff oil) and mechanical LSD definitely needs LSD oil.
If it's not in the diff, then other causes for the stuff you talk about include worn out CV joints.
https://www.sau.com.au/forums/topic/480519-rear-end-bind/#findComment-7932142
with the exception of coil overs the car is all stock as far as I know, with it being so new to me I havent had a chance to get it on a lift and really check things over. I did notice when changing my fluid (using standard gear oil) that there was a fair bit of rtv sealant that had oozed out from the cover and for some reason on the drain and fill plugs.. so someone has been in there before and I suppose it is possible its been molested. I'm waiting on a bunch of bushings to come In including diff bushings and I plan to open it up and get a good visual of everything while ive got it out.
I will definitely check my cv joints though, thanks for the advice!
https://www.sau.com.au/forums/topic/480519-rear-end-bind/#findComment-7932144
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
