@PranKif I have not misunderstood you mean the type of engine?  it is an bmw n47 150cv cammon rail.  mounted cp3 r90 pump and cpc 8 hole injectors.  and then the usual things: exhaust, intercooler, filter, camshaft with higher profile etc.
Edited by darrix
1 hour ago, darrix said:
@Predator1I don't want to do any engine conversion.  I want my engine.  I'm interested in doing 2.8 bar.  then I will see the spool later
It was a joke. This is a Skyline forum. We know nothing about BMW 4 cyl diesels and how their compound turbo systems work. So we recommend suitable Skyline related suggestions.
I see, okay, so I think the best option then is to directly run a -12 fuel line and inject it straight in the turbine housing. We usually do that on very high powered Skylines... better known as an afterburner.
I used to drive a Ford econovan, which I ended up welding the diff then putting in a v6 from a VN commodore.
When it was was a carby 4 cyl that did the best key bangers and could keep on driving at full throttle up a hill with ignition off. Good times. Funnily enough it also blew a head gasket. No forum posts involved  just fixed it and continued to ping its tits off. I miss that heap of shit
So yeah I know how diesels are cool
Hey mate, pull your head in. You come onto this site, talk utter incoherent garbage, and then call someone an asshole. Good work, you'll get your answers doing that.
It is clear that english is not your first language and are having trouble getting your point across, as nothing in the way you say things makes any sense to any of us.
If we know what you're on about sure, people will try to help you, but I suggest SAU is not the place to be asking about compound turbo diesel modifications on a BMW.
  • Like 1
4 minutes ago, darrix said:
because of the forum.  I thought it was a general forum and you could talk about everything
You absolutely can talk about everything. I have 2 BMW's myself. But it doesn't mean people here will know what you want to learn.
  • Like 1
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
