1 hour ago, darrix said:
@PranKI don't want to learn anything, at least for now!  ._.  .. I wanted to solve the turbo problem that does not pressure.  but everyone tells me to put the n2o.  I don't use n2o or these games
What EXACTLY is the problem ? Turbo that does not pressure, what the hell does that mean ? No boost at all ? No boost on one turbo ? Boosting, but not as much as you would like ?
You really need to explain, elaborate and detail the symptoms of this so called problem - if infact there is one.
  • Like 1
@PLYNXThere is no point in answering this.  I only asked for one problem.
then I have already said what my problem is ... when the big turbo starts running it no longer makes 2bar .. I wanted to reach at least 2.8bar.
what's wrong with you? sorry.....
7 minutes ago, Predator1 said:
Did you replace the flux capacitator while at it?
Of course, it was a little hard to come by and difficult to travel through time to get 1 without it but got there in the end.
It's those damn school holidays i tell you. They must also put funny stuff in the water over in Europe too.
  • Haha 1
  • 3 weeks later...
Try to directly inject LN0 in your turbine housing. Best mod, ever.
    • Of course you can. That was a waste. Straight down one oil drain gallery and out the sump hole. Could at least have run the engine a little (obviously with at least minimum oil level on the stick).
    • Oh really? Maybe I'm being silly. I'll get some more shots. I had it higher but found that it went too high after a drive, I never knew this but exhausts can move around a bit when hot (makes sense, just never knew) and when it was higher it would make nice cooking plastic smells. That said, I could put some heat tape on a'la 90's R33 exhausts     Ha, I've spent a lot of my life in castle hill waiting for cars to be done. I think I'd prefer something closer but thanks D.
    • @Duncan Yes, changed filter every time. I don't have the service manual for the car yet (Car was imported and they removed everything when importing). I've been using the oil change threads in the forum as reference.   @Milkmun The second oil change was after ~4 months after the first months and I wasn't sure about reusing engine oil that was opened. The third oil change happened within 3 weeks of the second oil change and I used the previous leftover oil to just "clean up" the system. (Poured it through while the sump plug was open")
    • I left the ceramic coating off this bit, hopefully it just comes off after a few drives.   The gap between the spokes is too tight for anything on a stick, its only marginally bigger than my finger. I have to use a brush to get in there and its a big reason why I thought I'd try the coating.   Absolutely will do. I have EBC Blue Stuff pads to put on the front which will make them a bit dirtier. I'm hoping a pressure wash will just get most off. The shine is different to most, its very thin but seems very well 'attached' so hopefully it lasts.
