Hi, Im in the middle of converting my r32 automatic transmission to an rb25det manual gearbox, I know that the r33 yolk is supposed to be swapped on the r32 for the tailshaft and some people are saying you might have to get the tail shaft cut down too, Basically im just wondering if i got the r33 yolk and got it put on the r32 auto tailshaft if it world fit, The gear box and tranny seem to be the same size so i dont think id have to get it cut but thought id ask for some help. Also if anyone knows if i need to get a custom mounting bracket for the rb25det manual to fit properly or the r33 one will fit.
Thanks guys!
No, you cannot just take the yoke from the uni joint on one and replace the same piece on the other. It will be the wrong length (even if the uni joints are compatible, which I'd assume they are not).
You have to take the front half of the R33 tailshaft and the front half of the R32 tailshaft to be cut and shut together. You end up with a front half of tailshaft where the front end suits the gearbox and the back is R32.
In order to do this successfully, you need a measurement of how long the resulting front piece needs to be, because it's not the same as either the R32 or R33 piece. If you go to Hardy-Spicers almost anywhere in Australia they have done so many of these that they already know what length you need. Otherwise you will need to very carefully measure the required length from the back of the gearbox to the centre CV joint, allowing for movement of the spline in the gearbox.
Are you talking about the gearbox crossmember? There are 3 of these commonly found in these Nissans, with various gearboxes. Marked A, B and C. You will need one of them. I think, because you're starting with an auto, you might even get lucky and need the one you already have. But if it won't work, just go to the wreckers and buy and/or borrow the other 2, with a promise to return the one you don't end up needing.
    • GTSBoy on your suggestion on another thread I had a look at those injectors and ended up getting them because of the quality.  Got the expensive ones.
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
