Hello, i have a problem with my ac on my skyline, when i press the ac button the compressor turns on but not blowing cold air,
i filled up the ac system and its not leaking
when i filled it up i had about 7-8 bar of pressure without compressor running, i checked pressures using the ports where you fill ac. when i turned ac on (compressor running) i still had 7-8 bar of pressure, shoudn't it go up? anyone know what it could be? only thing that i can think of is a faulty compressor, how can i diagnose this further?
https://www.sau.com.au/forums/topic/480540-ac-dosent-work-r33-gtst/
If the TX valve is faulty, you can tell by watching the gauges, the low side will draw into a (near) vacuum. So the clutch is definitely engaging on the compressor? And the gauges aren't moving at all? Are you sure the couplings on the charge ports are seated correctly and contacting the schrader valve? Is the discharge pipe getting warm at all? How did you charge the system? Did you evacuate/reclaim the system prior to recharging? Did you vacuum the system prior? How much gas did you put in?
If you did everything correctly, and you're sure the gauges are working, and the clutch on the compressor is engaging, and the gauges aren't moving at all, then the compressor has failed internally.
yes clutch is definetly engaging, i filled up to 500G i think, cant remember exactly but i filled up to what the stickers said in the engine bay, yes i vacumed the system before filling up ac with an ac machine we have at work, cant remember if the low side got a vacum when i tested it, i will test it again this week, i also did a climate control diagnostic, and it did not throw any codes, so  most likely a tx valve or compressor like you said, thanks for info :)
  • Like 1
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
    • Me coming to check the thread to see if my manual boost controller was set up correct......
    • Ah yes but were you responsible? In the time I've had it (just before Christmas) I spun off the track twice and drove into things twice, so four separate incidents.. in two outings. Luckily I have a full OEM GTR front end to put on which is hopefully not a precursor for further, future, more expensive mistakes to come. It is some consolation that anyone who would want to buy my Altia bar would have to paint it anyway, the guards, too. (if they can get over the asymmetry). Hopefully over the weekend I will disassemble and see how badly things are bent. From what it looks like, the headlight has actually just been pushed back and bent the headlight support (which .. somehow... crushed the guard in). I guess the headlight plastic is strong stuff.
