Hi people,
I have an R32 GTR that has been sitting since 2006. I’m about to start a resto on it. The panel where the blue I.D tag and the factory stamped vin will need to be replaced due to rust. The new panel will not have the vin stamp in it, will this cause issue with getting it rego again. I have all the sales invoices and old rego papers for it in my name.
I would phone up your local road authority and speak to them about it. Bit of a risky thing to make a decision based on forum recommendations. You'll probably get your answer, but I would still phone and speak to them to have peace of mind.
I don't have any experience in this, but I would suggest you make sure that you know what you need before you take that plate off.
I would also suggest documenting it thoroughly (the removal and replacement) as potentially someone might spot it's changed or doesn't quite look right if you ever try to sell it. Interference with the VIN plate is a 100% walk away moment for me at the moment.
My two cents... good luck!
Frenchy's performance make reproduction plates with all the original information on it, which can be obtained from Nissan fast. I've been thinking about doing one for my 33 as it looks like this, emailed them they said no problem. I even have new genuine plastic plate retainers purchased from Nissan.
Having a new vin plate is an easy fix too, can be any plate with the correct numbering riveted on. The most concerning thing is if your doing anything in the firewall with the original chassis number stamped into it. Without that intact, that is going to cause big problems, as there is no real way to verify what actual chassis and therefore vin it is. It would have to be restamped into firewall, and legally I don't know if you can just do that. This is what your going to have to check with the authorities on.
https://frenchysperformancegarage.com/collections/nissan-skyline-r32gt-r/products/blue-nissan-skyline-r32gt-r-id-plate
Along with agreeing with the recommendations above to ask your local rego authority, I would do this.
Cut out original panel segment with the number stamped in it. Keep it.
Make new panel with same number stamped in it looking exactly the same as the Nissan stamps.
If anyone asks, show them the original panel and the photos of you cutting it out of the same car and holding it next to the new panel being welded in and the photos of you holding it next to the new stamps being done.
  • Like 1
I’m definitely getting 1 of these from Frenchys. I didn’t know anyone was reproducing them
I sure plan on doing lots of homework before cutting anything. It’s my car and I’m ow it’s not dodgy but I’m still freaked out doing it
  • Like 1
This was a thought but I don’t think stamping it yourself is aloud with the authorities. But I will ask the question and the other issue is you can’t buy stamps in that font and size. These would have to be made and they would be expensive to do so.
9 hours ago, trel said:
I had this issue a few years ago with another 33 we had. VicRoads wouldn't register the car without the 6Uxxx number being stamped onto the strut tower so we went to an import yard who did it for us for $10.
I know a few importers through work so I will ask if this is something they can offer.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
    • New rear lights, filler panel sprayed, cleaned and back together    before, during, after shots 😍
    • 100% is gyprock, I agree. Slip of the keyboard. Haha! I left my indicator bulbs out to save a bit of weight.
