Hello, everyone I'm looking to convert my rb25det s2 into solid lifter setup just wondering how miles I can go before they need adjustment. I plan on daily driving, street racing, and drag racing is there anyone on here with first hand experience with the rb25det solid lifter conversion not looking for opinions real experience only thanks.
https://www.sau.com.au/forums/topic/480585-rb25det-solid-lifter-adjust-periods/
56 minutes ago, GTSBoy said:
I only have opinions. Because I know what I'm talking about. But seeing as you don't want them, I'm not going to answer.
Damn, how else am i going to find out about these things without actually asking..?
No, you made it fairly clear that you only wanted first hand experience with converted solid lifters.
Typically, you never need to adjust the clearances on solid lifters on any factory Japanese engine. They don't wear. Japanese camshafts don't wear*. Japanese lifters/followers/buckets don't wear.*
*unless the engine is owned/operated by a moron and not serviced.
  • Haha 1
Thanks for the info! yah should of changed the wording. I just got a reply from raw brokerage they said the same thing solid lifters rarely need adjusted if set correctly. Just wanted to know before I build my head with solid lifter conversion but they also stated that supertech and tomei run different shim styles and there not compatible with each other. So I'll be looking into that more. I wouldn't of converted to solid lifter if I had to adjust them ever 4k miles that's doesn't sound very fun that's why I asked before I dropped a few thousand into the head. Thanks again if u have any other info on this conversation please give me some insight. ?
Why not convert to solid? Hydraulic replacements cost about the same and I'll get better reliability and no worries about valve floating. I plan on ramping up the power more as I get comfortable with it so I will need the extra rev range when I upgrade turbos. also I won't have to replace parts and I'll know that a lifter isn't gonna drop. More power more torque if it starts ticking all I got to do is drop some shims in it's just a win win and I don't plan on revving it to 9k-10k probably won't need to 8.5k is what I'll probably have the cut set should be with in my power band my tuner says he can probably keep it under 8k. Spend money now save money and headaches later. I had some lifter tick before I pulled the motor my fuel cut was set to 7.8k. why is there so many haters on the forum?
I wouldn't call them 'haters' - the situation is we have had these cars/motors for many many many years now, I'll throw in another many for good measure. These ideas that were thrown around 15 years ago like, changing my head to solid lifters and bolting a turbo on my non-turbo skyline have been discussed to death and there is a reason that so few people do it.
The cost of taking a head with hydraulic lifters and making it solid is not 'about the same' as servicing a hydraulic head.
Have a look at the Supertech Solid Lifter Head Conversion Kit, it's got 168 pieces in the kit. Then you've got the associated machining and labor costs.
Looking at a recent invoice from my machine shop, the cost to refresh my hydraulic head was $500 (AUD). Let me know what your solid lifter conversion is going to cost you including, parts, labor and machine work.
Don't take this as me saying don't do it. It's your car, your money. Unless you and rolling in cash though, there may be other things you could spend it on that give you a better return.
  • Like 1
  • Thanks 1
Yes, it's going to cost money and also be reliable and I am building the block to hold 1,000hp. Don't like the hydraulic lifters solid is the way to go for me the benefits I will receive more power, more torque and adjustable rev range so why not dump the hydraulics? I'm not sure why anyone would wanna replace dropped lifters all the time with a hydraulic setup I doesn't sound like a good time to me.
Love it, chasing 1000hp. Please post up a build thread.
When you say it's going to 'be reliable' as part of your regular service maintenance, will it include things like an annual strip down of the motor and refresh? (provided the motor lasts a full year that is)
You are in America right?
  • Like 1
  • Haha 1
Do it. 1000hp daily driver build is money no object kind of stuff.
What about drive train? Clutch?
Can't believe you are even considering valve clearance intervals when talking 1000hp. You can check clearances in 30 minutes.so much other shit is going to cause issues.
  • Like 1
    • You're 20 years too late mate. Used to be 80% skylines back in team trackday days
    • There's a lot of drug money on that side of Sydney. Just sayin'.
    • At SMSP, I mainly see Hondas, M cars, A90 Supras and of course, plenty of Evos. Have not seen a single R32 ro R34 Skyline on the night sessions that I've been to. That's really saying something.
    • I like mine. Much better than stock. Like i said before the reverse/parking cameras look even worse than normal, still useable. When you buy one make sure it's the latest version. Heaps of cheap ones that run the old hardware and software. Got mine from AliExpress. Mine is quick no lag, boots up 1-2 sec. Menu is fast. Netflix is fine and so is YouTube. Android Auto is random taking 3sec to 15sec. Most of the time it's quick. Very rare it doesn't connect. But that could be a phone thing.   Now I think they use a Pixel 3XL to run this whole thing which i guess is fine, but the problem is that some apps will not work on old hardware like Disney Plus  Maybe Prime Video too 🤔. they will not update. Iv'e tried getting the APK Disney + but i still couldn't get it working. I have a Data sim installed so i have internet all the time. You can't Hotspot off your phone and connect Android Auto at the same time. Not that you need too, if you want you can hotspot off your phone and run any internet map app (google maps) and you can run the Spotify app on it's own (the app runs better than android auto) You can still access the INFINITI intouch system for all the o.g stuff    P.S i got new non Polarization Sunglasses too 😎
    • I also don't mean to rain on your parade. But with a 5-10k budget for road only? I'd want to check confirmation that everything IS working correctly and I'm with @GTSBoy for a plan of action here. I'd be checking subframes, bushes, exhaust hangers, interior bits and generally QOL things and CONFIRMING they are working right before thinking about motor. You can get 250KW+ on stock RB26 hardware by simply removing the built in restrictors and tuning the stock ECU. If you want purity that's as far to take it, which I would be worried to do and won't think the budget would allow for when earnestly checking for 30+ year old car stuff.
