Hi, I've got a problem that's getting on my nerves.
Fuse at the bortom left side (10a) keeps on popping when i turn the key to on.
I got problems with my climate control and fan blower and i have tried everything.
Googled like a maniac and still can't find anything that sort my problem.
Can this be related?
I got three climate controls, so that isn't the problem ?
I also tried removing all connectors to the fan blower motor, I've changed the temperature relay to.
Please help, I'm getting desperate.
https://www.sau.com.au/forums/topic/480588-10a-electrics-fuse-problem/
I'll tell you what it powers. It powers the things that stop working when it is blown or removed.
Have you looked at the wiring diagram?
I haven't got the the R33 manual here, because...ugh, why would I? But the R34 manual shows many circuit diagrams with numbered fuses. An example being #5, 10A from the ignition switch, running the sunroof & power windows. I'm not suggesting that that's your fuse (although it could be!)....just pointing out the level of detail available in the easily accessible documentation.
Edited by GTSBoy
  • Thanks 1
The wiring diagrams that I find is hard to read, to small. The only thing that I have problem with is hicas and climate control/fan blower.
I'm going to follow the wires tonight and try giving power to see if the fan blower will move.
I got 12v at the wires to climate control.
Don't search for wiring diagrams, search for a service manual, particularly the factory service manual
  • Thanks 1
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
