Unsure if this is the right forum to post under..
I'm looking for opinions on whether I would be better to go 20de +T or put a 25 cam into it?
My friends said 25 cam, I personally want a turbo but can't do both due to high compression?
This probably makes no sense. (Sorry) just very confused.
https://www.sau.com.au/forums/topic/480604-help/
17 minutes ago, JordanRochelle said:
Sorry, 25 cam shaft?
changing the cam to any possible other cam in an RB20 is a total waste of time and effort. Turboing an RB20 is also a waste of time as the result will be disapointing.
https://www.sau.com.au/forums/topic/480604-help/#findComment-7933087
Why disappointing? I've seen plenty of 20de+t that go hard... I'm not chasing power or huge numbers. Just something fun
https://www.sau.com.au/forums/topic/480604-help/#findComment-7933577
2 hours ago, GTSBoy said:
They only go hard above 5000rpm. Everywhere else they suck.
This ^^^^^
Having previously owned an RB20DET with a few mods and now having a RB25DET NEO
the difference lower down in the rev range is massivley noticeable
https://www.sau.com.au/forums/topic/480604-help/#findComment-7933605
Honestly...sell that rolling wreck for whatever you can get for it.
Buy a going RB25.... if you have to.  Otherwise just about any other car will do till you get off your P's.
Reason, adding a cam is a waste of $$$, changing the motor to an RB25 makes more sense, but is a costly and ultimately futile build.
Plus by the time you cut out the rust, redo the window seals, fix up the front end, upgrade the brakes, suspension, and other stuff, you are up for big $$$.  Buying an RB25 with all this stuff done and then setting out to improve it even more will cost much less and also  - in the end - be a better car.  Plus side of a 25 is what you take off can be resold.
The only possible reason for continuing with that RB20 is you are starting with a 'blank canvas', but its 12 months to 3 years of hard yakka getting it done.
https://www.sau.com.au/forums/topic/480604-help/#findComment-7933606
I'm in NZ so don't have the issues on Ps etc..
I have all the parts of this body, the body is straight no rust anywhere.. I just want to keep my 20de cause I have it torn down ready for rebuild. I can get a full rebuild kit cheap asf cause my partner works in parts. Could also get a det block too but I'm just not sure.
I don't want to put the 25 cam shaft into it, I'd rather get a det block or a +T but the boys reckon a 25 cam would be better ??‍♀️
https://www.sau.com.au/forums/topic/480604-help/#findComment-7933882
so they think an RB25 Cam (assume you are talking inlet only, there are 2? ) in an RB20DE is better than either an RB20DE+T and an RB25DET?
thats potentially the most retarded thing I have read on here in a while. Even with the best camshafts in the world (2 of them) in an RB20DE it is still a heap of shit. even rebuilt.
https://www.sau.com.au/forums/topic/480604-help/#findComment-7933886
And just to hit this one again....the difference between the 20 cams and the 25 cams is so small that the time, money and effort spent on the swap would be better spent buying 6" railway spikes to hammer into your own skull.
https://www.sau.com.au/forums/topic/480604-help/#findComment-7933889
The boys at the local kindergarten?  Can they tell you how it is different (and I can tell you that as GTSBoy says its SFA) and what difference it will make?
https://www.sau.com.au/forums/topic/480604-help/#findComment-7933914
Good on you for resurrecting another Skyline.
Looks like a big project. If you are in for the long haul, and if I were you, I would look at getting the 20det bock, pistons turbo and build it from the bottom to top. I am not too sure that is all the differences. But do your homework and calculate what it is going to cost, then double it. A good 20det screams nicely.
Good luck.
https://www.sau.com.au/forums/topic/480604-help/#findComment-7935147
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
