Depending on what head you plan on using...since you are using the rb25de head, you have no vvt. So the best option would be to use the rb20det loom as it has no vvt as well, and the rb20det Power FC...make sense?
I think the best place to start is what car do you currently have? Then work from there.
My preference would be to use an RB25DET PFc if you can. You dont need to have it running the vvt, and it is $400 cheaper.
Do all years of RB25DET have variable valve timing?
The project car the motor is for is a 260Z, so that is neither here nor there but it does allow me to have free range of what skyline parts to use.
Are all the sensors common between the RB25DE and the RB20DET i.e. will the loom plug into everything or will some chopping and changing need to be done.
Will this affect injector style?
R32 came out with the two engines =Rb20det, Rb25de....
I assumed you were putting it in a different type of car other than a skyline....
saying that the sensors might not be the same between the rb25det and rb20/25de...not so sure if they are compaitble, which may mean getting all 25det sensors...added cost
I got my Power FC and HC for $1600 brand new...not too expensive. They do come up now and again, and arnt hard to get hold of.
yup Ap Engineering version on the RB31DET.
Ive got a mate Using a RB25de (with 26 internals) and he is using the rb20det loom, using the 25de knock and oil pressure sensors. The only difference in the two is the AAC valve i think...check the difference between the two engine sensors (ie rb20 to 25de) to see if there any different. I did and only came up with the AAC valve being different between the two models....and use a rb20 afm :D
edit/ the rb25de and rb20det use the same injectors - top feed red tops...same cc as well i think....
  • 6 months later...
I'm also using an AP PowerFC & H/C for the RB30DET that I picked up for $1100 delivered, 1 year old.
With your setup you will need the RB20DET loom and an AP Engineering PowerFC.
The injectors and sensors between the R32 RB25DE & R32 RB20DET are the same.
If you went with the R33's VCT head obviously the use of a R33 RB25DET loom and RB25DET powerfc would be required.
I'm unsure if the R32 RB25DE loom has the extra's such as MAP sensor & knock sensor wires running back to the ecu. I would have to check the wiring diag in the engine manual. Either way its not hard to run a couple of wires you are missing back to the ecu.
Ok cool, thankx. soory to be a pain but would it be too much trouble to check the wiring diagram?? just trying to get out of changing over to the rb20det loom, could i use the 25de loom with the addition of an aftermarket boost controller? thanks again mate, help is much appreciated.
I wouldn't worry too much about the N/A and turbo loom differences.
Wires can always been ran back to the ecu. All you need is the pinout.
If you want the r32/r33 engine manual let me know. It contains the wiring diags.
I decided to throw a few x 3 Jonnie Walker cans back tonight (with family) so I'm kind of tanked. No good me looking at a wiring diagram. :rolleyes:
hehe sounds good. Mate would it be alot of trouble of for you to e-mail me the engine wiring diagrams? so u rekon i could use the 25de loom and use a boost controller for the turbo, along with the programmable FC to suit an rb20det? harrr what a mouth ful!again, many thanks for the help...
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
