All,
I have painted over years but with minimal knowledge so I am trying to up my knowledge.
here are my qestions:
paint procedure is as follow with points needed to be done on each stage, is that correct ?
1. Primer( if bare metal) or grit 1500 to create area for paint to stick if there is already paint. This will be 1 to 2 coat. one needs to wait 24 hours before going from primer to sanding to doing base coat.
2.Base coat, 2 to 3 coat. some say 4 to 5 coat which ?
Waiting around 15 mins after each coat.
3. top coat, I don't really understand what this is, what is the top layer?
4.laccuqer or clear coat , 3 to 4 coat. around 15 to 20 mins after each coat
5.polish
temperature is what is I have in garage which is around 15 to 20 degree.
I have painted a metalic car using above and paint is sort of matt , is there specific laquer to be used with metallic?
https://www.sau.com.au/forums/topic/480620-few-general-questions/
After the first coat you give it a sand and hollows etc will show up  for you to fill. Top coat is the last coat. Laquer is for show cars...shows up every deficiency in the metal.  Requires many coats. Enamel is easier and more forgiving.
8 hours ago, drifter17a said:
When you say sand with 600?
would you fill hollow with bonding compound or next layer of paint
Depends on how deep the hollows - there is a special spray on stuff you can apply locally.  Have done some painting but I'm no expert ...have a look at the pros on YouTube.  Also you can get free advice from the auto paint shops.
On 17/06/2020 at 3:29 AM, drifter17a said:
All,
5.polish
hi mate,
some paints require a Ground Coat which is usually the metallic colours. just double check if you need this or not.
I wouldn't fill the minor scratches with bog.. just use primer filler or a spray putty.
just to make it clear. will you be using acrylic paint or twopac? I would not recommend using two pac paint in a garage as you need a proper booth. with acrylic you can get away spraying your car in your garage and depending on the coverage I would personally put on 3-5 coats and 3-4 coats of clear on top.
Also, with acrylic paint, you need to wait for to paint to cure for couple of days, wet sand and and cut and polish after.
Thanks bud
would ground coat be same as the first wet laquer before base coat, seen that on youtube and didn't understand it
when you donbase coat, i was 15 mins between coats and after 30 mins following last coat do laquer or clear coat otherwise as I understand you need to sand it with 1000 to create but surface if doing it say next day
re paint types, i know mine is metallic but don’t really know different type of paint and whether mine is acrylic
    • I believe mine is helical and not clutch type. During drifting one wheel was spining as if it was open diff so bought kazz 1.5 way and has sat on my shelf for the past 5 years as I want to learn shiming process and do it myself   in meantime thought I change the diff oil hence post here. So any 75-90?   i am pretty sure r34 are helical not clutch lsd as standard . That is gtt ones
    • Throw between gears are so much that is getting annoying. I have pro short shifter on my mx5 and e36 and love it . Skyline is getting unbearable    would syncro issues and short shifter is no no? Anyone mind explaining a little on why before i buy cube
    • No. Well, some people "seem to use redline shockproof in the diff". Most do not. I would only contemplate it if you have badly worn CW&P gears. And no. No-one in their right mind has ever put ATF into a diff. Any normal diff/gear oil of the right viscosity will do. Whatever takes your fancy. Castrol, Nulon, Penrite, Redline MT range. Whatever. It's just gears. 75W-90 or 80W-90 is typical. I think that GL-5 is hard to avoid these days, although I think that a GL-4 is probably preferred, given the vintage of the equipment. At least Redline offer a number of GL-4 oils. If you have a clutch type LSD instead of the VLSD, then of course you need a proper LSD oil. Anything from any of the same names above. If you have a helical LSD, then it does not require LSD oil, and the recco is the same as for the VLSD. You don't want the LSD friction modifiers in the oil for a non-clutch type LSD if you can avoid it.
    • You may want to list it up for a little higher - This price is much lower than you may realize. Here you're pretty much selling to people who most likely already have these things on their own rigs. S chassis people eat this stuff up like you'd not believe.
    • I had my car for over 10 years and done around few thousand miles but never changed the oil. thinking of changing it.   what brand and viscocity would you put in ? people seem to use redline shockproof in the diff   on  contraty seen others using atf dexron 2 or 3 so wanted to check. is it 1 liter?
