Hello everyone!
Over the course of the last few months, I've been planning to get the Stagea my buddy has had sitting in his backyard for who knows how long and turn it into a cool daily wagon.
After bringing to my house, fitting the engine and gearbox (almost, had to source a gearbag crossmember because they lost it), I was ready to go and buy an airbox and MAF sensor because they lost that too, and then I went and got new spark plugs because they were old and buggered, and a bunch of hose clamps, bolts, part of an R31 wiring loom because a dog made a meal of the auto trans plugs (??? seriously?!?!), then, a full set of injectors because the old ones seized up which was just dandy, then, we found a leak in the water pump so we did a new pump/timing kit (I'm used to Subaru's so if one part is faulty, I just replace the lot, it's easier), then we re-assembled the timing kit wrong and had the retaining spring behind the pulley so we fixed that, and a partridge in a pear tree. :)
Now, all it needs is a few small bits, a stereo which I'm transferring from my other car and a damn good detail.
This is my first factory turbo car so please enjoy this dose video I had to make. Even after all this nonsense, I still think it's rad.
1997 Nissan Stagea RSFour.
  • Like 1
https://www.sau.com.au/forums/topic/480622-gday-new-stagea-rsfour-owner-in-vic/
9 hours ago, Timmy0240 said:
Hello everyone!
Gidday! Looks like the grill from an N/A car and a pretty non-standard radiator. Any other mods?
  • Thanks 1
Ooh, is the grille from an N/A? I like the unicorn badge so it’s definitely staying!! Haha. Um, it has a 3 inch turbo-back and a Nissan Sports diff-back muffler. The radiator is an alloy one my buddy got for it. :D
58 minutes ago, Steve85 said:
Oooh, i like the green. It looks cool, unusual, love it. Welcome. :)
Ditto! It’s also got gold accents which is kinda weird, looks factory though! And some remnants of the factory pin striping which I want to fix. I’d like to keep it a tidy stock example. :)
Thank you! I like it here.
  • Like 1
28 minutes ago, KiwiRS4T said:
Pics of my (former) RS4  - front shows the stock grill with RS4 badge:
I do like that grille, but I also like my grille... too many options! Lol
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
