Hey all, yesterday, I came back home and when I turned on my street, my engine started stalling and dying out. It was in 1st and I had to keep revving it gently to avoid stalling. It lost all power and wouldn't go above 5km/h.
I wanted to go park it, but 500 meters before my house, everything went back to normal.
First thought, was to check the MAF sensor. I noticed that my HKS filter was disintegrating and had let some particles past the MAF sensor and most likely into the intake, very few though, since most of it was caught in the mesh.
I disassembled it and cleaned it using MAF sensor cleaner and as advised in another post, reset my ECU but unplugging the battery, pressing the brake 3 times and giving it 15 minutes.
Obviously, upon restart the engine was cold, so it idles at about 800-1,000 RPM. I went ahead and warmed it up driving and did a few pulls. No stuttering or any power issue, sounds and feels healthy.
After parking, it started idling strangely like this :
Engine from Cabin - Streamable
Here's what it sounds like from the outside, hear that strange "high pitched" sound ?
Engine from bay - Streamable
I'm no mechanic, but could it be a faulty MAF sensor or idle air control valve ? I'm curious as to why it only happens after the engine warms up though.
I got the car over a week ago, it's 100% stock besides a boost controller set on low boost and this just started.
Thoughts ?
Let's start with the obvious. You, that is you, will have to work out where that noise is coming from. It is probably unrelated to your idle problem. It sounds like it might be the power steering pump, or something else rotating down there, simply because of how it appeared to get louder when you pointed the camera there. But the CAS is in the same general area, and it could be noisy/dying bearings or some other rubbing problem in there. But we can't find the source of the noise across the internet. Put some time and effort into working out where the noise is coming from. Do you know how to use a length of hose to find noises?
Then the idle. I haven't seen such sudden, short, small changes in idle speed before. When my IACV is dirty/sticky and not responding to the ECU's drive signal properly, it will jump up to really high revs and behave much worse than that. Nonetheless, I would suggest that what you are seeing is the ECU responding to something changing (engine load caused by PS pump, possibly the rpm signal derived from the CAS) and simply driving the IACV more open/closed in response.
The revs if warm seem high. Did you make sure when you reconnected everything that it's all tight? Sounds like a hiss. That engine bay looks pretty weathered and I would hazard a guess and say some rubber hoses have split from being brittle after you moved the maf around.
5 hours ago, KiwiRS4T said:
CAS looks pretty weather beaten...maybe check the bearings? And of course clean the IACV.
Yeah, the idle air control valve was my first thought, but I wasn't entirely sure, considering the fact that when cold, it seems perfectly fine. I'll look into it tomorrow !
I'll start with trying to give the idle air control valve a clean up.
Also, I just noticed something strange. I was watching a video on cleaning up the IACV, and it mentioned unplugging the TPS connector and adjusting the IACV screw to set the idle. I checked on mine, and for some reason, the cable seems deleted, but the connector is still in. It was always like this, so I doubt it's THE issue, but still doesn't seem normal nonetheless !
Any thoughts about that ?
It's idling at 600rpm. If anything, this is slightly low, not high.
This is a major WTF!!!???!!??. The standard ECU needs the TPS. It cannot know you are at idle if it can't see ~0.45v coming back from the TPS. It also uses it elsewhere in the operational range to know about "accel pump" functionality, and so on.
It won't be the IACV. As far as I can tell, it appears to be working. The way your tacho moves by small defined amounts looks like the idle speed is responding to the ECU changing the opening of teh IACV.
That is the part that I don't get. It was working flawlessly before yesterday. I even looked at pictures sent by the seller before I bought it, and it was indeed this way.
I mean, don't get me wrong, the car performs really great and sounds absolutely healthy whenever it's not idling, which confuses me.
Others have covered the idle issue..and they are right its bloody hard to diagnose on the internet.  Its a challenge for you and your mechanic.
Looking at all the white 'powder' in the engine bay plus the noise...I'd say you have [or have had in the past] a water pump issue.  Does it leak at all?
I just had another look. There are 2 loom plugs on these TPSs, and the lower one appears to be connected.
I have little direct experience with playing with these on vanilla RB25s. RB20s had a similar TPS, but the ECU used it differently. And the TPS on my 25Neo is essentially the same as vanilla 25, but I haven't had to mess with it. So I've forgotten which plug is which. You may have no real problem here, depending on what is disconnected.
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
