Hi. I have a built RB25. Since I got the car a year ago, it's had this annoying knocking sound. Does not sound like it's any different depending on engine temp.
I don't think the sound has gotten much worse. Been two times for mapping in dyno, one drag race and 13000km on the road just last summer. Now after using the car for a few days the oil starts to get a strong smell of fuel. Injectors is tested and cleaned. Nothing wrong with them. Does not look like the engine has any noticable blow by either.
Engine is bored, CP Pistons (87mm), Eagle rods. All bearings are ACL Race series. Compression test was: 9.9, 9.9, 10, 10, 10, 10.5
Anyone had the same sound from their's RB? Listened with a stethoscope and knocking is most noticeable from sylinder 6 on block- intake side.
Edited by KimHaugli
https://www.sau.com.au/forums/topic/480630-built-rb25-piston-slap/
Your compressions are quite low but I'm guessing it was built that way.  The noise sounds a bit of a worry .  Were you able to  narrow down the source to high up (valve gear) or lower down in the block?  Is your VCT working OK?
Sound was faint in the head and a lot more noticeable on the block. VCT should be fine. I guess the sound would come from the front if that was the problem?
Yeah, so, the obvious suspects for block noise are piston slap, gudgeons and rod bearings. Bit hard to say which it might be from here though.
The video from inside the car sounds more like a spun bearing than piston slap. Hard to believe that it has been making that noise for 13000km without either it exploding (if it was a bearing) or you taking it apart to find out what the hell is wrong. There's no way that I would drive it if it sounded like that.
The video from inside the engine bay sounds so much more like a stuck/collapsed lifter than anything from lower down. There's no way that I would drive it if it sounded like that.
All lifters has been opened and cleaned out before I started using the car again this year. Many were saying lifters last year but they looked perfect.
Last year when I started to get fuel in the oil is when I parked the car. Got the map checked and it was way too rich. Assembled the head, got off to dyno. Noise was still there and 3 days after, strong smell of fuel in oil.
On 20/06/2020 at 2:10 AM, GTSBoy said:
That just sounds like lifters too.
TAKE IT APART!
Or at least take it to a decent mechanic.
I find it weird for it to be the lifters as everyone told me it was last year. Took them out this winter and they have been opened and cleaned out. Still the same sound, and no one looked like beeing broken.
After using the car a little the last weeks the sound is getting worse when the engine is cold, and is more noticeable now when warm. So the engine is coming out ?
This actually is a really interesting post... to start, a small amount of  Piston slap Is actual a normal occurrence in forged builds under certain conditions believe it or not.
1# Forged pistons are honed/bored at slightly higher than stock piston to wall clearance over factory cast pistons
2# Forged pistons and cast pistons dont have the same expansion under heat, forged pistons expand more hence and take more time too and thats why they need a greater tolerance. Sometimes depending on the application... forged pistons when in the bores can even rock back and forth to the point where they go “click clack” when moving them by hand. Crazy to think about but look it up on youtube from HPacademy.
#3 Forged pistons usually have a central gudgeon pin location, where as cast/stock are made with an offset pin location on all OEM pistons, which helps reduce noise.
Now, from my experience with my forged rb25neo, i do have some very slight slap on cold start but within 5-10 mins it is 100% Gone. This is considered normal with forged motors
In your case with ur engine warmed up still slapping loud like hell and with ur compression readings, it may be that ur clearances are completely off and this is 100% the machinist/engine builders fault for not doing it or checking it correctly.
Sorry to hear about it but keep us updated, very curious to know what happened or if its something else entirely.
5 hours ago, Dil-Dog said:
But keep us updated, very curious to know what happened or if its something else entirely.
Yeah, I will come with updates when I get it out.
I guess there will be scarring on the side of pistons or cylinders if the engine has piston slap and been driven that far with it? When I had the head off I could not see any damage to the cylinder walls, but you never know what hides lower in the cylinder when piston is in.
1 hour ago, Dil-Dog said:
Yeah man, good luck and take pics and get back to us
Just got it confirmed 30 minutes ago. Piston slap ? but the mechanic said that the sound was not that bad and that he would not strip the engine because of that. Since my engine is built with larger pistons, he told me to replace the thermostat to a normal one (85-90c). The one that is in now opens at 63c. He thought the sound might go mostly away if the engine got up to normal temperatures. So I'll try that first ?
  • 5 months later...
Sorry for the really late answer, had a lot to do the latest months. But I guess I figured out what the problem was. Previous engine builder/company have done everything wrong... With the sound in the engine and it starting to fill fuel in the oil I was pretty sure that rings or pistons were worn. What I didn't expect after 40k km was this.
-Completely worn piston skirts
-Completely worn cylinders, and honing was done wrong. Honing marks were straight as an arrow in 80% of ALL the cylinders.
-Cylinders were so oval that if you turned the piston 90 or 180* it would not fit down in the cylinder.
All bearings looked great with no marks or wear, so that was not were the sound came from. New build starting early January when the parts arrive. Just got my new block finished at the machine shop, bored to 86.5mm and decked. Can't wait to get started and do it right this time!
20200724_193118.thumb.jpg.2f65829125f2948c19c46d30c84dde47.jpg20201010_210118.thumb.jpg.dd7494ef1fa7b27d23b3815e0d0d4511.jpg20201010_204328.thumb.jpg.123cc1ce01741eed4faebb707b6c5025.jpg20201010_205509.thumb.jpg.c5aa6baaffa9acbf65d42fe8387d34a6.jpg
    • I did read your post, a few times actually.    Done. Followed this step. [Negative probe should be on the cars chassis. Positive on the wire.]   Did this partially.. now that im reading this over, i only unplugged the LED lights. [Start as said above by unplugging everything (unplug the lights, and switches.] When you are talking about the switch, you're talking about the knob thing on the right side in the drivers seat right? If so, i need to take that apart?  [Now at the switch, there is a wire from the fuse, to the switch, so out your positive on that terminal. It should read open circuit. If it reads something, especially a stupid low value, the short is somewhere between the fuse and the switch.] At this point are you referring to the connector by the headlights?  [If that's fine, now put the positive probe on the wire that goes to the headlight (at the switch plug). If it reads stupid low, the fault is from the switch, to the headlight.] Did this. I can confirm that the LED lights aren't the issue [Another quick test, is take the whole LED light setup from the left, and plug it into the right side, does it still blow the fuse? If you put the right hand side led light setup on the left hand side wiring, does the left hand side wiring now blow?  If the blowing fuse swaps from right to left doing this, your LED lights are the issue.]
    • Hey was wondering if you ended up installing the R33 GTR speed sensor - I found one too and wanted to confirm it's a direct swap into the R34 6 speed?
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
