Car: 1988 A31
Engine: RB20DET
Power: 190rwkw 15psi
Performance Mods: hybrid RX7 turbo, 3inch exhaust, Hybrid front mount, Boostworx remap, blitz pod filter and HKS EBC.
Dynoed: Boostworx
When: Month ago
  • Replies 42
Car: R32 4 door
Engine: Rb25det
Power: 215 rwkw @ 13 psi
Performance mods: FMIC, Apexi 3 inch exhaust, WoahBro pump, TSL Remap with Rb20det ecu, AVCR, Stock turbo.... upgrade coming soon.
Dynoed: Turbo Tune (most accurate in adelaide)
When: not long ago
  • 1 month later...
Car: 1989 cefiro
Engine: rb25/rb26 hybrid
Power: 580whp 434ft/lbs TQ @ 1.2bar C16 gas
Performance Mods:87.25mm wiseco forgies 9.8:1, egale H beam RB26 rods, acl bearings, N1 oilpump, R32GTR crank:with custom collar, block line bored, and extra oiling for 26 crank, head quench removed, three angle valave job, hks 272 dur 8.5 lift cammies, hks springs & retainers, Tomei adj cam gears, tomei 2mm head gasket, ARP head studs, GReddy TD06H-25G 16cm turbine, GReddy SS exhaust mani, GReddy GT 50mm wastegate, 555cc injects, rb26 power fc de-jetro, Splitfire coil packs, GReddy intake Mani with Q45 TB, nismo intank fuel pump, bosch inline fuel pump, nismo fpr, power enterprise timing belt...etc...
Dynoed:UNNATURAL INC. Portland, Oregon, USA
When: NOV 12 2008
Mode:awesome
Edited by cefirosliderRB2.7
  • 4 weeks later...
Car: s2 R33 4 door
Engine: RB25det
Power: 182rwkw
Performance Mods: fmic,3inch staight thru,splitfires,0.5bar,stage 2 shift kit,standard turbo dumppipe & front pipe i think?
Dynoed: west torrens dyno centre
When: 16/8/2007
Mode:shoot out mode 4
Car: R32 4 door
Engine: Rb25det
Power: 283 rwkw 20 psi
Performance mods: FMIC, AM Performance exhaust and Split Dump, Bosch Motorsport pump, TSL Remap with Rb20det ecu, Blitz EBC, 3071R with GCG rear housing
When: last sat
now redone...
  • 4 weeks later...
Car: s2 R33 4 door
Engine: RB25det
Power: 182rwkw
When: 16/8/2007
hay man i have the same car but im guessing yours is auto mine is a factory manual series 2 which are pritty rare im told. its got full exhaust no cat, fmic {1000 hp rated} pod it put out atw 165kw before the full exhaust and cooler so i am keen to see wHAT IT HAS NOW. i hope around 255 or more hp dont no ill have to find out. it was also not on shootout mode i found out later. any way cheers. nm8u.
Edited by nm8u
Car: R34
Engine: RB25DE (non turbo)
Power: 128 kW N/A, 171 kW NOS
Performance Mods: 3" stainless steel catback, apexi power fc, splitfire colipacks, airnix trust pod filter, 55hp ZEX nitrous oxide kit, custom extractors
Dynoed: Southern Hi Tech Dyno (128kW) and the Extreme Horsepower Show - Profix Marion Dyno
When: December
Mode:a shoot out mode, not sure which one
Car: 1988 A31
Engine: RB20DET
Dynoed: Boostworx
When: Month ago
Just had my car tuned at turbo Tune, making 214RWKW on 15psi with a T3G turbo replacing the worn Rx7 turbo, dyno sheet to come soon, or Simon-R32 can vouch for it, you were at Turbo Tune when my car was being tuned.
Car: 89' A31 Cefiro
Engine: RB20DET
Power: 120.4 kW on stock boost. Made 142rwkw last March.
Performance Mods: 3" turbo back exhaust, FMIC, Aftermarket Fuel Pump, Pod Filter.
Dynoed: Some Aussie Mufflers place on Port Road. When: 20th Jan 08
Mode:Shit knows...
Pod was extremely dirty when It was done... looking at increasing the boost in a few weeks. :banana:
Car: ca31
Engine: rb20det
Power: 142rwkw (peaks at 12psi then fades off to about 10psi with the stock ceffy actuator)
Performance Mods: R34 turbo, k&n pod, lightened flywheel, hd clutch, walbro 600hp pump, 3" turbo back
Dynoed: springy motors
When: couple months back
Mode: shootout
Does this sound about right for a 34 turbo upgrade?
I'll try find my dyno sheet later and post a flick up
Car: 89' r32 gtst sedan
Engine: RB20DET
Power: 206.9rwkw @14.5psi
Performance Mods: 3" turbo back exhaust, Blitz panel filter, FMIC, gtr injectors, garrett hiflow (33 comp machined out, AVO .73 exhaust) rb26 pfc modded to fit rb20, splitfire coilpacks
Dynoed: CREATD Motorsports
Mode: Not sure doesnt say
Needs: z32 afm, fuel pressure reg, EBC and as much boost as it can take :cheers:
  • 4 weeks later...
  • 1 month later...
    • Hi, is the HKS  Tower Bar still available ? negotiable ? 馃
