Car: 1988 A31
Engine: RB20DET
Power: 190rwkw 15psi
Performance Mods: hybrid RX7 turbo, 3inch exhaust, Hybrid front mount, Boostworx remap, blitz pod filter and HKS EBC.
Dynoed: Boostworx
When: Month ago
  • Replies 42
Car: R32 4 door
Engine: Rb25det
Power: 215 rwkw @ 13 psi
Performance mods: FMIC, Apexi 3 inch exhaust, WoahBro pump, TSL Remap with Rb20det ecu, AVCR, Stock turbo.... upgrade coming soon.
Dynoed: Turbo Tune (most accurate in adelaide)
When: not long ago
  • 1 month later...
Car: 1989 cefiro
Engine: rb25/rb26 hybrid
Power: 580whp 434ft/lbs TQ @ 1.2bar C16 gas
Performance Mods:87.25mm wiseco forgies 9.8:1, egale H beam RB26 rods, acl bearings, N1 oilpump, R32GTR crank:with custom collar, block line bored, and extra oiling for 26 crank, head quench removed, three angle valave job, hks 272 dur 8.5 lift cammies, hks springs & retainers, Tomei adj cam gears, tomei 2mm head gasket, ARP head studs, GReddy TD06H-25G 16cm turbine, GReddy SS exhaust mani, GReddy GT 50mm wastegate, 555cc injects, rb26 power fc de-jetro, Splitfire coil packs, GReddy intake Mani with Q45 TB, nismo intank fuel pump, bosch inline fuel pump, nismo fpr, power enterprise timing belt...etc...
Dynoed:UNNATURAL INC. Portland, Oregon, USA
When: NOV 12 2008
Mode:awesome
Edited by cefirosliderRB2.7
  • 4 weeks later...
Car: s2 R33 4 door
Engine: RB25det
Power: 182rwkw
Performance Mods: fmic,3inch staight thru,splitfires,0.5bar,stage 2 shift kit,standard turbo dumppipe & front pipe i think?
Dynoed: west torrens dyno centre
When: 16/8/2007
Mode:shoot out mode 4
Car: R32 4 door
Engine: Rb25det
Power: 283 rwkw 20 psi
Performance mods: FMIC, AM Performance exhaust and Split Dump, Bosch Motorsport pump, TSL Remap with Rb20det ecu, Blitz EBC, 3071R with GCG rear housing
When: last sat
now redone...
  • 4 weeks later...
Car: s2 R33 4 door
Engine: RB25det
Power: 182rwkw
When: 16/8/2007
hay man i have the same car but im guessing yours is auto mine is a factory manual series 2 which are pritty rare im told. its got full exhaust no cat, fmic {1000 hp rated} pod it put out atw 165kw before the full exhaust and cooler so i am keen to see wHAT IT HAS NOW. i hope around 255 or more hp dont no ill have to find out. it was also not on shootout mode i found out later. any way cheers. nm8u.
Edited by nm8u
Car: R34
Engine: RB25DE (non turbo)
Power: 128 kW N/A, 171 kW NOS
Performance Mods: 3" stainless steel catback, apexi power fc, splitfire colipacks, airnix trust pod filter, 55hp ZEX nitrous oxide kit, custom extractors
Dynoed: Southern Hi Tech Dyno (128kW) and the Extreme Horsepower Show - Profix Marion Dyno
When: December
Mode:a shoot out mode, not sure which one
Car: 1988 A31
Engine: RB20DET
Dynoed: Boostworx
When: Month ago
Just had my car tuned at turbo Tune, making 214RWKW on 15psi with a T3G turbo replacing the worn Rx7 turbo, dyno sheet to come soon, or Simon-R32 can vouch for it, you were at Turbo Tune when my car was being tuned.
Car: 89' A31 Cefiro
Engine: RB20DET
Power: 120.4 kW on stock boost. Made 142rwkw last March.
Performance Mods: 3" turbo back exhaust, FMIC, Aftermarket Fuel Pump, Pod Filter.
Dynoed: Some Aussie Mufflers place on Port Road. When: 20th Jan 08
Mode:Shit knows...
Pod was extremely dirty when It was done... looking at increasing the boost in a few weeks. :banana:
Car: ca31
Engine: rb20det
Power: 142rwkw (peaks at 12psi then fades off to about 10psi with the stock ceffy actuator)
Performance Mods: R34 turbo, k&n pod, lightened flywheel, hd clutch, walbro 600hp pump, 3" turbo back
Dynoed: springy motors
When: couple months back
Mode: shootout
Does this sound about right for a 34 turbo upgrade?
I'll try find my dyno sheet later and post a flick up
Car: 89' r32 gtst sedan
Engine: RB20DET
Power: 206.9rwkw @14.5psi
Performance Mods: 3" turbo back exhaust, Blitz panel filter, FMIC, gtr injectors, garrett hiflow (33 comp machined out, AVO .73 exhaust) rb26 pfc modded to fit rb20, splitfire coilpacks
Dynoed: CREATD Motorsports
Mode: Not sure doesnt say
Needs: z32 afm, fuel pressure reg, EBC and as much boost as it can take :cheers:
  • 4 weeks later...
  • 1 month later...
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
