Hey Guys,
Some more threads of interest to those wanting to know more about Ceffys and other nissan sedans with a bit of grunt or those wanting to compare there mods or see what bang for buck people are getting for their buck.
Same as the other sticky threads NO COMMENTS or SPAM in this thread, this is purely to post your Dyno Sheets. Any comments or questions can be made in HERE
This is the format they should be in:
Car:
Engine:
Power:
Performance Mods: (ie. clutch, turbos, exhausts...)
Dynoed: (where)
When:
Mode:
And attach or insert a pic of the dyno sheet.... do not post if you dont have a dyno sheet.
https://www.sau.com.au/forums/topic/48064-show-us-what-ya-got-dyno-sheets/
  • Replies 42
Car: A31 Cefiro
Power: Approx 330rwkw
Engine: Rb26DETT
Mods: RB36DETT swap, 8l sump, 600cc injectors, A/m cams, HKS adjustable cam gears, Custom turbos - equivilant to hi flo 2540s, Hybrid bar and plate cooler, twin 3" exhaust, Nismo fuel pressure regulator, HKS 1 bar wastegate actuators, Wolf3dV4 running MAP.
Dyno run info: performed at SST in Perth in shootout mode(accredited), restricted to 1 bar boost, rich tune. Tune has since been leaned out a touch but have not got a chart for that run.
Car: A31 Cefiro
Engine: RB26DETT
Mods: RB26DETT, Custom turbos - equivilant to hi flo 2540s, HKS adjustable cam gears, A/m cams, nismo fuel pressure regulator, Bosch 040 pump, 600cc injectors, twin 3" exhaust, Wolf3dV4, Hybrid bar and plate cooler, 8L sump.
Needs: Forged internals
Dyno run info: Performed at SST in Perth in shootout mode, running 1bar boost pressure.
Car: R31 Skyline GTSII
Engine: RB30ET
Power: Approx 253rwkw
Mods: VLT T3/4 Hiflow Turbo, Wolf 3Dv4, full 3" mandrel system, JPC Cam, Bosch 036 injectors, Bosch Motorsport fuel pump, Large IC.
Acheived on SST dyno Perth, in Shootout mode on 14psi
Never mind the HP look at the torque :D
  • 3 weeks later...
Car: CA31 88 Cefiro.
Engine: RB20DET
Power: ahhh, read the sheet...
Mods: bleedvalve 12psi, 32psi fuel pressure (which as you can see = bit too rich) 3 1/2inch??? exaust, ceramic clutch, Jun lightweight fly wheel, pod, bit of 3inch bit of pipe up to pod, dodgyish catch can. I think thats the most of it.
Where: Murcry Motorsports SAU dyno day, so on dyno dynamics shootout mode.
RUN DONE IN 4th GEAR!!!
  • 1 month later...
Car: a31
Engine: sr20det
Power: 190rwkw @ 13-14psi
Performance Mods: greddy t518z turbz, GTR intercooler, z32 afm, walbro 255lt/hr fuel pump, 550cc injectors, remapped ECU, pod+cai+heatshield, twin-thingy dumppipe to 3 or 3.5".... etc..
Dynoed: Unique AutoSports
When: 10/10/04
Mode: I don't know - it says shootout mode but doesn't have the "shootout 04" logo everyone else seems to have
ok heres mine:
Car: a31
Engine: RB26DETT
Power: 207rwkw @ 9psi with 472nm Torque
Performance Mods: Std Cooler, Std Turbos, 3" Straight Pipe Catback, Blitz SUS Mesh Pods
Dynoed: XTC Performance, Coburg
When: 10/10/0
When: 23/10/04
  • 4 weeks later...
  • 2 years later...
Car- 88 a31
engine- r32 rb20det
power- 170rwkw @11psi falling down to 9.5 by redline.
mods- 3" turbo back zorst no mufflers or cat, HKS mushroom filter, gtr fmic & impul chipped ecu, suspicions on the possibility of cams due to the very stong top end power. and high power figure.
Edited by r31et
Car: R32 Skyline - 4 Door
Engine: RB20DET
Power: 196rwkw @ 12psi
Performance Mods: GTR fuel Pump, R34 Turbo, 3inch Cat back, Extreme Clutch, FMIC, Lighten Flywheel, K@N Air Filter,
Dynoed: In Malaga
When: About 6 Months ago
Engine: RB20DET
Power: 150.2 rwkw @ 14PSI
Performance Mods: GTR fuel Pump, Stock turbo, 3" Cat Back Exhaust , FMIC, Blitz SSBC, Apexi Pod
Dynoed: Morpowa in SA
When: Fri 14th Sep.
Have either a rooted Crank angle sensor or a dead knock sensor.
GAY.
So more once i got those looked at
Hey this is off topic but i have a couple of spare Crank angle sensors for a RB20 silvertop (old type and new), if you want you can borrow one off me to test it on your car to see if it fixes the problem, i also have some spare knock sensors too but i doubt it would be that (my car has had bad knock sensors for ages).
By the way i was the dude in the pearl white ceff with the vented front guards at Mallala accross from you on Saturday, i was behind you in a couple of runs and you were doing really well
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again馃様 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
