Havnt had the car long and speedo didnt work when i got it.
whiped the sender out and the gear was all munched but looked in the hole to check the gear in the box and low and behold.
anyone broken these before? can you replace the gear yourself without much hassle? or cheepish at the box shop.
was thinking about getting a 25det box in the future but may have to get it out of the way now.
 the sender that was init doesn't look like a nissan one anyone know?
https://www.sau.com.au/forums/topic/480662-shredded-20det-gearbox-speedo-drive/
yeah i thought so. looks like im in the market for a big box then.
I have looked at a few old posts re guarding the conversion to 25detbox and looks like i need crossmember and front driveshaft but have a few questions about some other things.
the cars an r33 factory auto 25det thats been converted to 20detmanual
can i use any of the old set up, ie flywheel/clutch/slave and master with the 25 box?
RB flywheel, clutch & slave are all interchangeable as long as you stay with push type, not pull type (ie, it will be different stuff if you get an R34 box, which is pull type).
You will need to work out what to do with a speedo drive. Depends on what silliness was pulled to make a 20DET box work in your car (which should not be easily compatible).
And when you say "front driveshaft", I presume you really just mean "front half of the tailshaft", yeah?
ok thaks for that. yeah i just read up on the 34 boxes about the pull/push type.
main concers was the clutch/flywheel as its got a hd clutch of some sort and was thinking thats gona be extra cost if would have to change at the same time.
the sender that i have is either a s14/13 silvia was was just wired up to the loom with the gearbox reverse/neutral i spun the sender with my fingers out of the box and moved the needle on the speedo. from what i have read the 25gearbox sender should just wire up if anything change the plugs.
yeah my bad i did mean tailshaft.
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
