Hi, I’m looking for alarm and immobiliser suggestions for my r33 preferably with central locking as my car doesn’t have that rn. And also would the installation process be easy enough for a beginner like me? Or would it be strongly advised to go to an auto electrician to do it. Thanks
I'm not sure by way of systems these days but an alarm/immobilizer is only as good as the installation. I wouldn't recommend doing it on your own if you're not proficient with electrical or mechanical. A professional will know how to hide it all well.
  • Thanks 1
What is your location?
I've had a Viper in my car since I got it (about 21 years). Has not faulted in any way shape or form in that time.
Properly installed by someone good at it. I could have done it, but it's better to leave it to a pro if you're not already good at doing it.
Get a separate screamer siren installed inside the cabin too. You can't easily work inside my car to defeat the alarm if it's going off because it's >120 dB in there and it hurts.
  • Like 2
I found Viper 3105VR. Is this a safe option? It seems to have everything thing I want and some however would it being on the cheaper side reduce the quality of its anti theft?
Immobilisers are all the same shit. They are just relays interposed in the ignition and/or starter circuits. The "security" is bypassable by restoring the original wiring. Most of the appearance of "security" is imaginary, in any of these things. The truly secure immobilisers, like the Brandts that were put into WRXs 20 years ago, were secure because the car could never be started, even when you wanted it to, because the immobilisers were shit.
Edited by GTSBoy
Id rather not say especially after openly saying my car has not anti theft system what so ever but Australia if that helps
Yeah good point because if you specified  a suburb or general area thieves would be all over you!
Seriously man he want asking for your address
It seems like this theft business is seriously worrying you.
Keep in mind that if someone wants to take your car; they will. Your car will be on the back of a tow truck and gone in a few minutes. There is no anti-tow-truck alarm or immobiliser system.
So if this is worrying you, some things to think about. Do you want GPS tracking with a notification system? Maybe just keep your agreed insurance value up to date?
The best security system is a locked garage. Add bollards if you're extra worried. Alarms are a huge waste of time and really only good for giving you hearing loss when it goes off for no reason but not much else. Transponder immobilizers might discourage casual theft/hotwiring but certainly nobody determined. GPS trackers, maybe with a tilt sensor/geofencing might help you locate your car if someone tries to tow it away and you're extremely quick to react.
Cause garage locks are so sophisticated and everywhere you go has a personal garage for every person... bollards for sure if the car is worth it but still doesn't help if you're out and about. Alarm is absolutely worth it if only to warn you (assuming your close by) or scare an amateur, mine certainly has when it used to be street parked. No point making it easier for them and i can't imagine anyone is putting alarm only systems in their car.
In relation to GPS, anyone determined enough to use a tow truck would use a jammer making it instantly redundant, and tbf would probably just put you in hospital if you caught them as i'd assume they're not your average thief.
  • Like 1
IMHO, the options are providing protection or mitigation from different risks or increasing the level of difficultly
  1. Alarm. Noisy. Scares some thieves off.
  2. Immobiliser. Prevents some thefts. Required by some insurance companies before they will insure your car at all.
  3. GPS. Allows you to track low level thieves. Also acts as an early warning that someone has set off the alarm or gained entry / caused damage. May be jammed prior
  4. Locked garage. Slows thieves down. Prevents some thefts. Not always available. Required by some insurance companies before they will insure your car at all (based on post code / residence type).
  5. Bollards. Slows thieves down. Prevents some thefts. Not always practical
  6. CCTV. May help after the fact if the police give a shit but unlikley
Preferably have as many as possible given your circumstances but accept the fact that it can be stolen no matter how many of the above are in play. Some people will use violence to achieve this.
I cannot believe the number of cars that I have purchased over the years that do not have 1 - 2. The first question that every insurance company has asked me after address is Alarm / Immobiliser. Do people just lie?
My preference was the South African ( where car jacking and car theft was a massive problem ) solution where they install an bunch of flame thrower pipes under the drivers side door sill.
So when they crims tried to jack it you stomped on a switch and it shot 1.5 meter flames on them.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
