  • 3 years later...
20 hours ago, Jumbotron said:
Did you end up going with the GTIII SS? What were the results and how are you liking it?
Life has an interesting way of distracting me from projects. I basically threw them on and I've been running wastegate boost on the stock tune. Response appears to be roughly the same as stock R32 GTR ceramic turbos. If you want a ball bearing CHRA and more power capability I think the Nismo R3 turbos were probably the way to go but they're discontinued now after being sold for like a year at best.
Yeah with the exchange rate these GTIII-SS are tempting, about the same price as the -9s...
When I look up -9s these days some suppliers claim they're discontinued by Garrett. I don't know what the truth there really is.
They're such old tech that every Taiwanese/Chinese knock off turbo manufacturer has their version for sale anyway.
  • Like 1
The interesting thing about the -9s though was the ceramic ball bearing, at least the 836026-5002S.
And id still take the -9 over the new hks turbos
-9s aren't a bad idea if the goal is to make more power, they just have a much narrower compressor map than the -7s and probably whatever TD04HL thing the GTIII-SS is.
Um, OK. But....my Hypergear highflow also has ceramic BB core. That's just come from some Taiwanese/Chinese factory. It's not like Tao builds the cores himself in his own foundry-factory. It's not rocket surgery any more.
  • Like 1
I hate to interrupt, there are enough internet rumors. I do build every single CORE in house that leaves my workshop including the one that you are using, as well as engineering work done on your turbo housings.  Reason been is I got shafted badly by a turbo joint 18 years ago when the business first started. I since trusted no one when comes to selling anything under my name, or I just don't touch them at all.
Edited by hypergear
  • Like 5
  • Thanks 2
Oops. Sorry mate.
It is both excellent to hear and also surprising though. The amount of work required to (effectively manually, not on a production line) build a core vs your low retail price point is why I presumed that you were buying cores.
But let's also be clear about what is meant by "build". At your price point I can't see you making cores from billet on a mill, even if CNC, or doing all the machine work on a rough casting. Surely the lumps of metal are sourced more or less ready to go from an Asian supplier, right? Maybe the same with shafts. I mean, you could turn shafts up yourself, but it's pretty slow going for items that are all essentially bulk order producable.
I was always perfectly willing to believe that you assemble your wheels to shafts, fit up bearings and do all the balancing. I actually expected that you would have been doing all that even if the core did arrive from a supplier with most of that pre-assembled.
Nevertheless, please accept my apology.
2 hours ago, GTSBoy said:
Oops. Sorry mate.
It is both excellent to hear and also surprising though. The amount of work required to (effectively manually, not on a production line) build a core vs your low retail price point is why I presumed that you were buying cores.....
Well, I do turn bearing housings, shafts and wheels on special orders, so you can order any wheel sizing preferred. Parts came from every where obviously, came from reconditioning turbos and been shafted, I know exactly where certain manufactures would stuff up. It sounds like I'm just assembling cores, but importance is I get to check if all parts are made to specs, if castings are right, all clearances and runout are right, balanced ok, bearing pack sounds before passing onto clients.   Building test cars, doing dyno testing and sponsoring drift cars is all parts of QC, so I get to know how a particular package performs before selling.
Yep, its slow and ineffective way of production, but I prefer less headaches.
Edited by hypergear
  • Like 1
  • Thanks 1
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
    • yeaaa that's why I haven't done any wiring to the stock ecu harness because I have the haltech, but then that leads me to the other question of "is the pnp harness really plug and play?" or would I have to still switch some pins/wires over because the pnp is for the rb25det neo harness, and not for the rb20de neo harness. was really hoping to find something to spoon feed me since so many people have done rb20neo + t conversions, but man this is rough.
    • Temu raptor, lol. At least the owner isn't your typical ranger danger lot
