I have a 1996 R33 rb25det
I have searched everywhere and I see a lot of topics on this but nothing has really helped me
First off I was having idle issues on start up. It was sitting around 500rpm so I changed my. Bov back to recirc starts good now. But still sitting around 700 which is fine..
But hadn't fixed properly. I'm still having problems coming to an intersection sounds like it's idle hunting. And it'll drop back down to 0 then bounce back up. I just have to keep the revs up to stop it from dieing.
I've cleaned the iacv and adjustig the screw and that didn't do anything at all I've checked for vac leaks and nothing. My thought was maybe the maf but that's sweet.
If anyone can help will be appreciated.
Edited by Kaden
https://www.sau.com.au/forums/topic/480675-idle-problems/
Hi Kaden,
When I had this exact problem in my 33 I cleaned the IACV and adjusted the TPS. (I had already given her fresh plugs, serviced the air filter and cleaned the AFM etc to eliminate anything else) In the end I put some tape around the IACV screw and then adjusted accordingly and finally she retained her idle after a lot of perseverance.....hoping this may be of assistance.
-jess
https://www.sau.com.au/forums/topic/480675-idle-problems/#findComment-7934604
May I ask?
What did the tape do?
I mean I've tried adjusting it doesn't seem to change anything. also which way did you turn it?
I probably should say it has new slpitfire coil packs and new spark plugs also. But that shouldn't be a problem. it's the same set up as my mate had and he never had a problem.
Edited by Kaden
https://www.sau.com.au/forums/topic/480675-idle-problems/#findComment-7934627
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
