So I made a mistake I wanted to clean my airflow meter on my car and now when i put it back it revs up to 4000rpm when i start it and when the key is on the on position there is a buzzing sound even at one point on the dashboard a light was flashing but thats now stopped. i also changed a vacumm hose that was already split in half (surprisingly my car was driving fine the whole time with it lol). maybe because the position of the AFM has changed its causing this? the vacuum hose i used is also a tiny bit larger that the OEM one, but i used  cable ties to secure it. dont know what to do now.
Just now, Ben C34 said:
You have done something else that is wrong
I cleaned the pcv valve was the only other thing? not sure if its worth mentioning but i did get some  degreaser and a screw driver to clean the crud inside.
Edited by silviaz
4 minutes ago, silviaz said:
ok the valve does rattle even though looks filthy as. do u think maybe cause the vacum line i replaced is slightly larger inside in the tube?
Diameter of line would mean nothing, a massive air leak will cause high idle.
A rattly pcv valve doesn't sound right. Block it off and see hat happens.
Your description of what you did isn't exactly useful.
I changed the pcv still the same and the power button on the dash keeps flashing and engine check light is on. hope i didnt fry the ecu, i didn't disconnect the battery when i done the work
slow down, take your time mate. silly mistakes can cost you big in the rb neck of the woods. i know rb26 tps needs to be set to .4-.5 volts....may not be the same for you but make sure your tps is set correct.
Yeah should be fine now, have been driving it for a few days drives great. i also found a vacumm leak! a hose was broken in half and i driving like that the whole time and it was fine lol. unless i accidently snapped it but doubt it cause it was pretty strong. though can't remember what my idle rpm used to be but its 500 now. i think its right.
On 6/29/2020 at 11:34 AM, Ben C34 said:
I did think there was a thing involved that caused the issue
Wanted to ask you something randomly because something clicked for me the other day. I didn't realise how valves work and you said that you can't bend a valve if the camshaft is on the bench (i couldn't visualise spinning the crankshaft without the camshaft without hitting valves. but i think i realised if the camshafts are removed the valves are closed? You don't even need to put it to tdc, is this correct? I imagine it makes sense because valves get pushed down and then released as the camshaft lobe spins around and hits it.)
So if i hypothetically wanted to replace my valve stem seals I could just set the motor to regular tdc (for aligning the timing chain later on) and then remove the camshafts then continue to feed rope down into the holes of each spark park hole and  fix each valve stem.  Is any part of my sentence incorrect?
That's pretty much exactly how it's done.
    • Holy smokes brother. If you get there before me, let me know if that was manageable with a hone. I still haven't done anything with mine and probably won't until I get the car MOT'd later this year so that I have another 2 years to do what ever needs to be done. I am at 86.5 now so at least I have the 0.5mm to go up from where I am, but that means new pistons at the very least. Honestly, might consider a stroker at that point.  Cheers
    • It's the adhesive holding the ceramic wheel to the shaft the fails on 90% of them.
    • Foreign debris, physical shock, boost leak, could be anything honestly. The danger in taking all the timing out of a tune/hitting the R&R corner is that even if the engine doesn't detonate your turbo is taking a lot of abuse from high EGT. Also, even if nothing goes wrong it is a journal bearing that is spinning at 100k RPM on boost. Eventually it goes through enough cold start/pressure cycles to wear it out.
    • I kinda accidentally saw this, and was interested, but It actually seems to replaces the whole center computer, using the existing screen and buttons. AND it may only be for a G37 and not compatible with a Japanese 370. So its not for me, but someone else may be interested to look into it. Its about $680USD. If I am understanding it right, it basically replaces/installs and android pc that integrates with the existing screen. But I could be wrong. https://gromaudio.com/vline/ The video I first saw was the following, with very little and unclear details.     Even if your not interested in the system, the video on their site was pretty comforting in showing how simple the whole centre comes out
    • hfygrte52 what side you looking for? Do you care what color car it's off? Found a white LH side on here: https://skylinespares.com.au/product/nissan-skyline-r33-coupe-rear-tail-light/   Aussie parts place but will ship to USA. Maybe get it before there's a tarrif on 25yo shit box parts
