G'day everyone
So for a while now my car has shown the same coolant temp which to me has always been low, so I finally decided to put in a new coolant temp sensor and WHOA it's now reading full hot, but the weird thing is my car, despite reading that high doesn't 'feel' hot.
  • No 'boiling' water
  • no loss of coolant
  • no milky stuff in oil
  • radiator can be touched without burning me
  • no smoke/fumes/burning smell
What on earth could be causing this? I might purchase a new radiator and thermostat but before I do, anyone got any advice on troubleshooting the issue?
Car is completely stock besides exhaust. Last weekend I changed plugs and did valve cover gaskets as well.
The before and after images of the temp with the new and old coolant temp sensor.
From one extreme to the other, does it jump straight to that hot position or gradually work it's way up there as the car warms up from cold?
Most would recommend installing an aftermarket gauge that shows actual temps before trusting the factory gauge. Would be cheaper than chasing a heating issue that may not be present.
Well it rises to half very quickly and then after say 10 minutes of driving will hit the top, stagnates at half for a little while. I鈥檓 hoping it鈥檚 not because I used an after marker temp sensor (tridon brand)
I think you will find that is the case. The position the original sensor was showing looked about right.
I might try giving the OEM sensor a really good clean and see if that changes anything, hopefully it can be revived
3 minutes ago, GTSBoy said:
FFS! How about applying a little bit of science?
What do you mean? I鈥檓 not that clued on with your original post man, how does one measure resistance
Did you mean to Google that? Or ask random People in a forum? Because I would suggest googling it
I came here to get some help, not be told to google my issue, i鈥檝e tried that. Any other good people in the forums have some advice that are willing to help a fellow enthusiast
2 minutes ago, robbo_rb180 said:
I don鈥檛 have a multimeter, maybe I should have made that clearer earlier.....but thanks
You've been told what you need to do to check the sensor is right. When you're relying on people to diagnose/repair it there is never a correct answer/solution with out doing some of the work.
https://www.supercheapauto.com.au/p/sca-sca-multimeter---digital/387595.html
One of the best tools to own when trying to diagnose electrical issues. A quick google search and almost every basic problem is fixable with out asking questions on a forum.
I miss the times before the internet was everywhere.
  • Like 1
Understood, that鈥檚 why I came here but i need to look at getting the correct tools so I can diagnose.
You gotta understand that not everyone has the same knowledge as you, so be patient....thanks for the help ?
Your words. Google that.
a multimeter is like, 15 bucks? or less off ebay. Less than the sensor anyway. Have you checked the coolant? maybe the refill was fkd up and the car is actually running too hot.
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 馃槂
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
