Hi there,
Im looking at buying a 6boost topmount manifold to sit on my 30/25 r34. Was wondering if anyone had any experience fitting them and how it went with fitment keeping in mind that i have the stock lines for the ABS there still.
Otherwise i was looking at Sinco as they offer complete setups that say that they will clear the ABS.
Thankyou,
https://www.sau.com.au/forums/topic/480718-6boost-manifold-on-r34/
with the caveat that mine is on an rb30 in a w34 not r34...
there is heaps of room to the ABS module and lines. The turbo is not parallel with the engine it is angled inwards at the rear/outwards at the front. The dump is close to the AC lines (insulation added) but nowhere near ABS.  The turbo compressor housing is forward of the strut tower and pretty close to the PS reservoir.
Basically...it's been made for that setup and uses the space well.
    • How old is the battery, it's more likely your battery is on its way out.
    • I reckon you'd get 90% off. My washer doesn't get between spokes very well. Haha! I love my Gerni!  Argh! Steam cleaning has its place for sure.
    • Hey all, I did a voltage test with the car (video attached) not running for 3 days. And here is some interesting stuff: - Battery voltage is 12v (I had the key in the ON position) - Drops to 9.76v while cranking then quickly goes up to 14.5v - You will notice there was a sorta slow start but not as slow as it usually is. - Idle surprisingly was better at just over 1,000rpm instead of 1,100 rpm. - I turned on the A/C, radio and headlights in the video and the voltage remains the same - I haven't cleaned the grounding wires on the chassis yet, that's next. - Battery drops to 12.6v when I turn off the car and wait a bit Seems like I might have a parasitic draw? I do have an immobiliser system which does drain the battery more of course but was wondering if there is anything else I should be looking at fixing? Does the ground wires on the chassis have anything to do with the low 12v?        SAU.avi
    • My lord that is some low oil pressure as minimum in the manual! I guess the big part will be seeing how it changes as the engine gets more spirited use.
    • Turbotapin   so I am about to be mounting mine up been waiting for the body to get finish at paint. I had a question. I was told our Speedo sensor it originally in the transmission but the cd009 is in the diff on the z. How did you get around this?
