Hi Guys,
I am soon to embark on removal of my OEM plenum and all the random stuff under the manifold but wanted to confirm that a hypertune plenum can actually fit in a bnr34 without having to remove the clutch booster and running a s-chassis clutch master cylinder?
its an ITB plenum like the one attached. now I'm not interested in the fact an OEM plenum is capable of power. this is an engineering project I'm embarking on with ITB drive by wire and will be comparing any manifold benefits around the 700g/s (900ish hp) mark vs the OEM manifold. there may be none, but I want the data. i have 6 EGT sensors for validation purposes.
thanks.
Should be fine if its just an RB26.  Only taller blocks have issues.  I have a greddy ITB intake on my RB34 high deck, and have had to shave the back off the master cylinder to get it to clear.  I still use the booster and an OEM clutch master.   The OEM plenum fit with plenty of room by comparison for an engine with the same deck height.  Your plenum will be 20mm lower than my setup.
    • As GTS mentioned, it takes a bit of faffing, some fiddling and a little modifying.  With the strainers, you can buy different styles. Some sit flat on the pump, some angle down.  Here are some photos of mine, ignore the ugly welds lol.
    • The smart thing is to actually locate the pump at the right point down the hanger, so that the strainer can stay sticking out at a right angle, but near the bottom. This is the perpetual hassle with retrofitting any different pump to the factory hanger. Some just go where you need it to, some need fiddling and faffing, and modifying of stuff.
    • Some updates. After a lot of praying and some inspecting of crank threads, we've found that they were both kinda munted but nothing seemed terminal. The other option was drilling and helicoiling the crank. That is obviously the last option so we decided to at least try to get a OEM GM bolt in to GM Specs. So after honing/linishing the balancer from it's .002" interference fit to a .0018" to .0015" to .0013" it eventually slotted on to the crank. ATI state the interference is nominally 0.0007-0.0009... so it's still snugger than ATI reckon and explains the issues we had to fit the thing to begin with. New GM bolt went in at 37 ft/lb then torqued 140 degrees after which was EXTREMELY   but it tightened up to 140 degrees and it was a lot of force. So all things considered, the balancer is secured to the exact specs that GM want with the OEM Stretch bolt, (that ATI say you can use..) and the balancer itself is seated and snug AF. So WOO. Engine is now back in the car with lots of swearing. Bellhousing bolts done up, driver side manifold is on, AC Compressor and hard lines are back on the car. Next step will be to connect various engine bits/wiring/intake/radiator etc. Then oil and coolant and ... test start it? And of course, looking into this issue... which actually doesn't look so bad - It looks like it can be twisted back into shape with a set of multigrips. Anyone wanna buy my bonnet? Boy it looks good over there and sunk cost sucks.
    • Also this may be a stupid question, but how would you recommend getting the strainer on a downwards angle ? as they tend to obviously clip to the bottom of the pump which usually sits level 🥴
